Dipricol Pyro Problem!!!
Old Mar 2, 2006 | 12:43 AM
jb903's Avatar
O.k. Put A Set Of The New Dipricol Optix Gauges In ( Look Soooo Cooool), But When I First Started The Truck The Pyro Gauge Worked Fine Went To Like 450 Then I Shut It Down. Went Back Out To Run To Town And I Look Down And The Gauge Reads 1200 But I Was Only 1/2 Mile From Home Going 20mph. Went Into The Store Came Out Started The Truck And Gauge Read 1200 Started Driving Goes To 1500, Stop And Let The Truck Cool Off And It Will Only Go To 1200 No Lower. What Gives I Checked All The Connections And They All Look Good, Is It The Probe? Any Help Would Be Great Folks. Thanks
Old Mar 2, 2006 | 09:12 AM
cquestad's Avatar
Probe or bad ground...check all connections again and then call your supplier and trade it out.
Old Mar 2, 2006 | 10:22 AM
06Cummins's Avatar
post up some pics!!! im going to be getting them soon and i cant wait to see what they accually look like in the truck..thanks, Jason
Old Mar 2, 2006 | 11:39 AM
jb903's Avatar
i wish i could post some pics, my old digi camera broke and im spending all my money on my truck. but they look great.
Old Mar 2, 2006 | 12:41 PM
TexasCat's Avatar
pyro
I have the dipricol guages in mine. They work great and look great in the daytime. The pyro at night is very hard to see. The back light does not work great on it, but the boost guage looks good at night.
Old Mar 2, 2006 | 03:36 PM
Mark Craig's Avatar
jb903,
Most likely your losing connection thru the connection at the back of the gauge, the probe is ok. Take it off and check each individual connection on both the gauge and the wiring harness. Take soemthing like an ice pick and make sure the connector isn't slipping back as it's plugged in etc.
Mark @ DPPI
Old Mar 2, 2006 | 05:26 PM
jb903's Avatar
well i disconnected everything and rechecked everything hooked it all back up and it went down to 200 seems to work a litle better but just cruisin in town at 20-25 its at like 600 is this right ? i let the truck sit for an hour came out and it still says 200? whatcha think next. thanks guys
Old Mar 2, 2006 | 06:49 PM
Nuttymopar's Avatar
Letting it sit and only 200 does sound normal. Dont' forget, that is iron and it takes awhile to really cool off back to normal temps.
600* around town doesn't sound too bad also. It depends how you are pushing your motor or not.
Old Mar 3, 2006 | 12:08 PM
Mark Craig's Avatar
jb903,
Sounds like you're A OK!
MArk @ DPPI
Old Mar 3, 2006 | 10:13 PM
dodgezilla04's Avatar
mine went bad after about 6 months, wouldnt go below 500* unless tapped on, just got worse, the guy I bought them from went out of business, so I emailed di pricol, they sent me a new one, no charge, and just asked for the broken on back, drop them a line, maybe they can help.
Old Mar 3, 2006 | 10:35 PM
turbowhine's Avatar
I have the di procol gauges, and they compliment the factory white face nicely. 200 deg. at idle is normal and so is the 600 around town. I have a 2004.5 and am getting the same results.
53 willys
Sep 7, 2010 10:52 PM
jdwest
May 17, 2009 07:53 PM
Triplggg
May 10, 2007 03:56 PM
Hired Gun
Jun 1, 2003 08:12 AM
HeberRam
Apr 23, 2003 02:05 AM
