Di Pricol EGT Gauge Question
Old Aug 24, 2004 | 01:23 PM
schorb's Avatar
Question Di Pricol EGT Gauge Question
Any owners of the subject gauge have the little white dot in the middle of the gauge fall off?
I've read a subject about this on the TDR website where guys are having this problem.
And is the red needle supposed to light up when you turn on your lights? The gauge lights up great, but not the red needle.
Thanks all.
Brian
Old Aug 24, 2004 | 01:58 PM
JRG's Avatar
JRG
As I remember it the first run of these gauges had an adheision problem.(the dot is glued to the inside of the face) The center of the gauge lights up the needle.
JRG
Old Aug 24, 2004 | 02:12 PM
schorb's Avatar
Oh okay. Hopefully I don't have the sticker problem.
My needle doesn't light up like my factory gauges. I guess I can't complain since it's the closest gauge that resembles the factory gauges out there.
Thanks JRG.
Old Aug 24, 2004 | 06:31 PM
Car_nut57's Avatar
Gauge
If the dot falls off return the gauge to the supplier for replacement they should do this under warranty. As for the needle illumination it does not seem to be quite as bright as the needles on the black faced gauges for some reason, but still visible. You can also check the bulb in the bottom of the gauge, some of these gauges had a small round bulb which is not as bright as the longer bulbs. It may help to install a brighter bulb.
WUnderwood
Feb 8, 2008 09:31 PM
tincan
Nov 12, 2007 03:57 PM
HappyGA
Jul 6, 2006 10:26 AM
jasonjones
May 18, 2005 07:36 AM
zkhoss
Apr 26, 2005 11:46 AM
