Crazy Larry Power Pup 2006
Old Dec 14, 2005 | 04:13 PM
Diesel 2006's Avatar
has any one try the Crazy Larry Power Pup 230hp deal. how good is it . i just bot the afe stage 2 air intake and Crazy Larry power pup and he told me stack with the Edge JUICE.
2006 dodge 3500 diesel 4+4
Old Dec 14, 2005 | 05:08 PM
John Rodriguez's Avatar
Tire Hater
Unless you feel like blowing up your turbo and or transmission, don't. Read up more about the supporting mods neccessary for that much fuel.
Old Dec 14, 2005 | 05:56 PM
i spoke jeff at etr diesel performance, he said the wood best way to go i had 03 with the tst & ez stack and it was fine
Old Dec 14, 2005 | 06:24 PM
RUSSELLMAG's Avatar
I've ran it. Seems pretty strong. I am also stacking it with the TST.
Old Dec 14, 2005 | 07:50 PM
juice's Avatar
What would be the difference with stacking the Edge Juice with attitude and the TST. Would you get them same results or would you have to remove the "Attitude". Also, is a stock fuel pump capable of handling that much fuel or did you have to upgrade your pump?
Old Dec 14, 2005 | 09:32 PM
StrokeThisCTD's Avatar
i ran it with everything else stock minus the straight pipe.
EGTs skyrocket QUICK. i hit 1500 at about 60mph as opposed to 1400 at 90mph on the performance program. on 230HP the truck has some MAJOR nut to it though.
Old Dec 14, 2005 | 10:00 PM
bbhzx12's Avatar
I ran the Crazy Larry with an intake and a 5" system. Truck hauled A**! EGT's through the roof though, it was fun but you have to be carefull.
Old Dec 14, 2005 | 10:02 PM
Kman9090's Avatar
I was told by bullydog that the 230 horse was for the duramax? They also told me that the crazy larry on the dodge was 180 horse. Well anyways I have the bullydog but have not downloaded the crazy larry setting yet. But I have it stacked with the regular edge juice and let me tell you it is insane. I can completly loose a couple sets of headlights behind ma and the power is unbeleivable. The stock in tank fuel pump on my 05 can keep up but I don't know for how long. As far the turbo I have the juice set to de fuel at 36 and I watch and make sure it doesn't get past that. But if you don't pay attention you can roost a turbo. But for my egt's with the juice on 5 and the Bully dog on extreme they only run up to about 1250 at a WOT to about 100.
Old Dec 15, 2005 | 12:21 AM
fredw's Avatar
the bully-dog CL does 210hp for the duramax, but has real bad shifts, overrevs on most upshifts, their is better out their
Old Dec 15, 2005 | 09:52 AM
Kman9090's Avatar
so the crazy larry setting on the dodge is 230hp? ANybody know what does what? Like how much duration, timing, and fuel pressure? I just put it on exteme and juice on 5 and it is awesome I don't know how well it would work though witht he crazy larry and then 100 more hp juice.
wah
13
Sep 12, 2021 10:19 PM
Dodgewincity
18
Jan 20, 2008 10:29 PM
Snojumper
34
Mar 18, 2007 12:27 PM
SmokinDodge12V
Aug 1, 2006 07:19 PM
kyle@ftlb
Mar 3, 2005 04:39 PM
