CP3 Pump Upgrade
CP3 Pump Upgrade
Is there any modification a person can make to the stock CP3 pump that will help the performance on a mildly tuned truck. I thought the Wicked FCA was the answer but after further reading I am thinking this may not help a stock truck.
the pump is not the issue, you can run dual pumps if you want its the injector size that can kill your truck and force you into buying a larger pump but there is no harm other then the cost of buying a stage 3 pump right off the bat.
I agree and Disagree....any upgrade will help even a stock truck. I am running stock injectors and CP3 with my smarty (Revo-TNT) and the TST set to 2/2 I was draining the rail horribly. So yes a CP3 upgrade will help, but Injectors will give you more BANG for the buck....
SOP, probably. You will get a quicker ramp up of rail pressure which will broaden the power band slightly. Top end gains will most likely be minimal unless pressure is already low
I noticed a sotp diff with just the wicked "regulator" installed (it's a $50 piece of the arson 3 kit)....plus some of the items, like the regulator are quasi "wear" items...eg. if your's (spring) is old and weak, it'll give some pep back....
I dont think you can go wrong with faster ramp and more flow in, thru, out of the CP3....e.g. II bag of parts or Wicked arson 3....
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
