Commander Update Testers Needed!!
Old Dec 6, 2006 | 10:46 PM
  #46
merrillr4's Avatar
Alright I did the second update. It finally took on the second try. For some reason I got a error screen telling me at the very end it could not update the commander and then it locked up the computer. But all is good now. I will drive in the morning and see if this will fix the fuel pressure problem. Thanks Quad
Rob
Old Dec 12, 2006 | 04:37 PM
  #47
J Double's Avatar
Originally Posted by qzilla
Just FYI, ALL Commanders are shipped with USB cables...
Quad
Quad...when did this start to happen? Is this a "special" USB cable? I was one of the first Commander recepients and I didn't get a cable. If it connects where I think it will, it looked like a standard USB 1.1 or 2.0 might hook up. Not the case after taking it to the truck. I have EGT and FP problems and need to get this update loaded. You have a PM over on CF about this. (Double J)
Old Dec 12, 2006 | 06:20 PM
  #48
Hunter11's Avatar
Double J, just call Quad's tech guys and they will send you one. I got one of the first Commanders and did not get a USB cable. His guys sent me one after I called about it.
Old Dec 12, 2006 | 06:26 PM
  #49
J Double's Avatar
Will do. No where in the update manual does it mention this or any other cable.
Old Dec 12, 2006 | 06:45 PM
  #50
Duallydog's Avatar
Wow, I missed a thread that I could use. I'm going to try to find a cable that will connect with what I have here.
Old Dec 12, 2006 | 07:19 PM
  #51
Hunter11's Avatar
Double J, that is assuming you have a USB port on your Commander. If not you have one of the Beta units like I had at first.
Old Dec 12, 2006 | 07:41 PM
  #52
J Double's Avatar
Doh! No USB port on mine. That would explain the confusion I've had on how exactley updates were supposed to be performed. The unit was already sent in once and nothing was mentioned about it being a beta unit. I think I deserve a "production" Commander with the journey I've had with this thing.
Old Dec 13, 2006 | 05:33 PM
  #53
J Double's Avatar
Well I take back my words. After talking to Quad tech it turns out I was sent a new unit afterall, to include USB port. I was under the impression my Commander was awaitng parts and that's what took so long to get it back.
I loaded the update so hopefully that will correct the erratic EGT and FP readings...luckily I had a USB cable from a camcorder that actually fits the Commander.
Old Dec 13, 2006 | 06:26 PM
  #54
rjm022's Avatar
my first commander was replaced two weeks ago. your company sent me out a new one then. so, since mine is two weeks old- do i need the update?? my tranny temp runs on 104 too! still experiencing the other problem for the other post. every once in a while my coolant temp flashes on the whole screen. checked the connections- it is tight! thanks.
Old Dec 14, 2006 | 11:16 AM
  #55
welndmn's Avatar
If you don't have a USB cord, its a standard Mini-USB cord,
Most electronics stores have them for under 10$
Old Dec 14, 2006 | 04:40 PM
  #56
CrazyFloyd's Avatar
2nd update
Updated my commander with the second update. Again, easy and works even better.
Old Dec 17, 2006 | 10:13 AM
  #57
cspot's Avatar
please add me to the beta list.....
Chuck
Old Dec 19, 2006 | 06:19 PM
  #58
texaspower19's Avatar
im up for doing an update i got mine back in feb, my buttons dont beep either like others but i dont care just didnt know if was supose too
qzilla
Nov 4, 2010 01:16 PM
qzilla
34
Nov 4, 2010 09:52 AM
qzilla
21
Mar 6, 2007 07:36 AM
