Code?
Old Aug 28, 2005 | 02:10 AM
Kman9090's Avatar
Code?
I have a 2005 with the edgejuice and today I went to smoke the tires a little bit and tried 3rd and ended up killing the truck. Well the problem is that it is now flashing code p0335 but the truck still runs fine. I do not know what to do does anybody have a solution? Also I would like to add after I killed it I then started it up put it in 2nd and then smoked them a little bit. Is this a major problem and what would it take to fix it. I am really kinda freaked out about it.
Old Aug 28, 2005 | 09:37 AM
Kman9090's Avatar
nobody???
Old Aug 28, 2005 | 10:09 AM
RamWheelsBy4's Avatar
The code definition is
P0335 Crankshaft Position Sensor Circuit
There is a code list in the Tech Facts menu on this site.
Don't know why this code would show up, probably few different reasons. If the truck is running ok and what caused it is no longer happening then the code will eventually clear itself. It will take a number of start and run sequences to clear. An OBDII scanner should be able to clear it, Autozone used to do this for free.
Old Aug 28, 2005 | 12:59 PM
doorguy's Avatar
Read a thread a while ago on a different site on the exact same thing. but for the life of me I can not find it again nor can I remember the explanation. It gave a good description on why it happened. I will keep looking, sorry could not help.
Old Aug 29, 2005 | 07:47 PM
Kman9090's Avatar
Thanks, well the truck reset the code itself and have had no more problems.
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
bkay
Mar 25, 2003 10:41 AM
