Clutch Slipping w/ Quad XZT?
Old Mar 17, 2008 | 09:55 AM
Mark Hodowanec's Avatar
My 2004.5 has a Quad XZT & otherwise stock except for tone ring mod, muffler delete & 315/70-17 tires. I was pulling a light trailer (3000 lbs max.)up a pretty good grade (10%) @ 60 MPH. I could have held it in 6th put downshifted into fifth to keep temps in check (I don't have gauges just figured it would be better). After downshifting, I would put my foot down & revs jumped 200 RPM. The downshift really put the engine speed into the power band - 2000 RPM. As soon as revs would jump would pull foot out of it - well within 2 or 3 seconds anyway. This happed three times or so before I realized that my clutch was slipping , and my speed was not shooting up that fast.
I have the original clutch in the truck, but don't pull trailers often, don't race the truck, and am very easy on the clutch. Even after this incident, the clutch seems normal and does not smell. I know the clutch got some extra wear, but is there any real damage? I was surprized that such a mild chip (65 Hp) like the XZT would put the clutch over the edge. Has anyone else had issues w/ the XZT and stock clutch? I really don't want to replace the clutch yet .
Old Mar 17, 2008 | 09:59 AM
GlennRMK's Avatar
How many miles are on the stock clutch?
Sometimes when they are on there way they slip easier.
Its only a matter of time.
Get the South Bend Con OFE. Real happy with mine
Old Mar 17, 2008 | 10:07 AM
northernwheeler's Avatar
I have slipped mine quite a few times, even passing in 6th when you put your foot down it would slip. Seems it will do it a couple times, then be good for a long time. When I first bought my 30' gooseneck it would do it often, then one day it started holding ok, so i have been taking it easy on it until i can around to putting a better clutch in it.
A friend of mine was slipping his bad, using a Diablo tuner, so he replaced his with an aftermarket clutch. Funny thing is, the one he took out still looked new, so i think they are pretty durable, but just can't hold the extra torque.
Old Mar 17, 2008 | 11:07 AM
85K on the stock clutch. Unless I burnt it with teh last trip, should not have been on it's way out. How much is a South Bend Con OFE? Not that I want to put a clutch in now, but I am curious.
Old Mar 17, 2008 | 11:12 AM
shineboy2's Avatar
Mine started slipping @ 60k w/ an XZT. S.B. OFE sometime soon.
Old Mar 17, 2008 | 11:45 AM
Elk_Hunter's Avatar
Mine has been slipping too. I only have 35K miles. I don't race and don't drive it that hard. With my edge chip, in tow mode (2), I can get it to slip in 5th and 6th gear. Stock it won't slip.
I've been looking into the Southbend clutch too.
Old Mar 17, 2008 | 11:59 AM
Yeah, I want the south bend really bad too, but i am waiting until I find somebody that has one I could try out. I tow heavy lots, and need a clutch with good street manners. That, and getting one shipped to Canada is looking pricey. I would buy one locally, but not many people seem to carry South Bend clutches up here, and the ones that do want a stoopid amount of money for them.
Old Mar 17, 2008 | 04:53 PM
dodgezilla04's Avatar
the ofe is great for towing. i pull my 10k travel trailer with it. its been in for about 14k miles. shifts really smooth, engages smoothly, and holds power....
Old Mar 17, 2008 | 05:40 PM
How much for the clutch if I install myself?
Old Mar 17, 2008 | 06:31 PM
GlennRMK's Avatar
$700
I see stock replacements for like $400-$600
$700 is not a bad deal
Old Mar 17, 2008 | 09:05 PM
mark i cannot answer on price. lary at the dtr store can.
it took me about 4 hours to install the clutch myself, alone. i dont have a lift. it isnt tough, just heavy parts.
Old Mar 17, 2008 | 10:42 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
You're my hero. I have had my butt kicked by this 06 w/G56. Your tranny weighs at least twice what mine does. I've been told it's a line up issue I'm having. I went with the OFE as well. Real beefy stuff. Can't wait to get it all back together.
Chris
sCreamin400
Nov 2, 2008 01:46 PM
hoehand
14
Nov 16, 2005 12:03 AM
roadranger
14
Aug 28, 2005 09:56 PM
jimjawz
17
Nov 2, 2003 09:44 PM
21
Nov 3, 2002 07:24 PM
