Chirp Vehicle Horn disable
I followed exactly what the manual says to disable the horn but I just can not get the horn to disable
. Any ideas?? The 07 in my sig. Thanks in advance
Yes chirps every time I lock the truck. I just did a search on horn chirp, there should be a yellow addendum in your owners manual saying how to disable it. I have 2 but nowing about killing the chirp. Guess I will have to go to the dealership have them do it.
I got an 06 mega cab about a month ago and I hated that chirp as well. I did what the manual stated and it did not work. I actually had to put in different combinations of button pushing to get what I wanted. It not only was the horn chirping feature that I wanted to change but I wanted to unlock all the doors at the same time. I wish I could rememeber what conbination of buttons I hit, but I can't, sorry. If there is anything else I can help you with, let me know. Good Luck!
I tried every combination I could, I just finally thru in the towel. I did have no problems first try with enabling the all unlock with one push of the unlock button and seat belt chime off. I guess I am heading to the dealer.
Thanks
jtnm
Thanks
jtnm
I'll get my manual and check it out.
ok here it is:
1) enter vehicle, close doors, insert key and turn to on position but don't start.
2) press the lock button and hold for at least 4 seconds not more than ten seconds. while still holding lock button, press the unlock button. you should hear a single chime which tells you you have changed the programming.
that's it. test it and see if it works!
ok here it is:
ok here it is:
ok here it is:
It also states to buckle the seatbelt before pressing any of the fob buttons. It says that it takes any other bells or alarms out of the picture. Tried it on my '03 and worked first time.
mitternocht
May 10, 2007 10:50 AM
schv
Jan 17, 2007 09:02 PM
Schmed
Feb 25, 2005 08:10 AM
