Changing springs at home?
Old Jul 7, 2008 | 02:44 AM
highrpms's Avatar
How hard is it? I have changed many gasser spings. I understand there is a special tool? Is the job intermediate or slightly above level work?
Old Jul 7, 2008 | 03:55 AM
D45's Avatar
D45
Are you talking about the front coils or the rear leaf springs?
Old Jul 7, 2008 | 07:14 AM
Bad-Duvall's Avatar
Originally Posted by highrpms
How hard is it? I have changed many gasser spings. I understand there is a special tool? Is the job intermediate or slighlty above level work?
I think he is talking about Valve springs..
If so. The job is not to bad at all. There is a special tool to use that compress all 4 springs at once.
You must remove injectors to do so and once you have them all removed just take something like a coat hanger (make sure to cut it long eunf so that it wont fall all the way into the Cyl) put in to to a cyl via injector hole and rotate the motor till that cyl is on TDC this way the valves wont fall into the cyl, Then just use the tool and chang the springs just like any other spring.
Old Jul 7, 2008 | 12:51 PM
highrpms's Avatar
Yes sorry, I did mean valve springs.
Old Jul 7, 2008 | 12:57 PM
RowJ's Avatar
... I understand there is a special tool?
see HERE
....You must remove injectors to do so....
There are easier ways to find TDC on each cylinder!
RJ
Old Jul 7, 2008 | 01:03 PM
Bad-Duvall's Avatar
Dang thats a nice lookin tool much better than the one i have.
Old Jul 7, 2008 | 01:35 PM
highrpms's Avatar
Originally Posted by RowJ
see HERE
RJ
That is an awsome tool. When you release it to put the new springs in how are the valves held in place?
Old Jul 7, 2008 | 01:53 PM
RowJ's Avatar
You DO have to be at TDC for the cylinder your working on. rotating engine 120* each time allows you to work on 2 cylinders for each position. Just do the math.
RJ
Old Jul 8, 2008 | 10:40 AM
Bad-Duvall's Avatar
see HERE
RJ
Was really easy and im bad at math Soo..
Old Jul 8, 2008 | 10:43 AM
dodgezilla04's Avatar
see HERE
RJ
yes there is, but the injectors need to come out anyway to use the spring compressor.
Old Jul 8, 2008 | 02:05 PM
RowJ's Avatar
Ok! Must be a 3rd Gen thingy?
RJ
Txwelder
Dec 31, 2011 12:02 AM
jmccart
48
Jul 23, 2008 12:34 AM
masonic-dodge
Dec 27, 2004 04:29 PM
masonic-dodge
Nov 17, 2004 05:37 PM
mr T
Nov 1, 2004 10:50 AM
