Can you stack on other chips if you already have the Edge Juice chip?
Old 02-13-2007 | 03:24 PM
Juiced01z06's Avatar
So I have the Juice Edge like I said before, so if I get the triple dog, those two work well together? I am just scared of messing something up. I will definitely be buying a GDP system for safety reasons. Are they hard to install? Which of the three kits they have on their website would be best? And then the clutch. How much will a south bend for my truck cost?
Old 02-13-2007 | 05:45 PM
And another question about the triple dog. I will need the monitor as well if I want to adjust levels while driving right? Can I do that with both the attitude monitor and the bullydog outlook monitor at the same time or do I need to get rid of one?
Old 02-13-2007 | 11:38 PM
jwb600's Avatar
no you dont need the monitor for it also. it plugs into your pcm/ecm port under the dash and you can adjust it on the fly that way. I ran the juice/triple dog stack on my 05 with no isses. I would set it on performance then drive it and see what you think. I have my triple dog sold otherwise I would send it to you and try it out. I liked the older power pups they seemed to have more smoke on the lower levels. not as much as the newer crazy larry. you may be able to get a power pup cheaper too. they just cant be upgraded on the internet like the triple dog. I like the edge monitor better thats what I ran on mine.
Old 02-13-2007 | 11:46 PM
jwb600's Avatar
I am happy with my glacier system so far, its very quiet unlike the fass pumps. I would say get the best clutch you can you will be glad you did. If you want to sled pull get a double disc. If youre just gonna drive it, get the clutch that is rated for 550hp and 1100 ft lbs. Ive seen that truck hold up to sled pull. If youre interested in a double disc, you will have to get a hydraulic upgrade kit also to install it. I had an 05 6spd manual before my 06, I learned a hard lesson on getting a cheap clutch. Ive seen the south bends hold tons of power and guys say on here their customer service is good.
91.5 beater
08-13-2008 08:47 AM
TexMexCowboy
08-01-2007 10:06 PM
Jvenne86
01-26-2007 11:03 PM
VikingDiesel
11-15-2006 12:24 AM
ataboy9026
12-28-2005 05:06 PM
Quick Reply: Can you stack on other chips if you already have the Edge Juice chip?
