Cabin Fever Upgrades
Old Feb 16, 2009 | 06:07 PM
D45's Avatar
D45
AD 150 and the Glacier cannister eliminator bracket:
Old Feb 16, 2009 | 06:08 PM
D45's Avatar
D45
Cometic Gaskets:
Old Feb 17, 2009 | 08:38 AM
paroxysym's Avatar
you will like those PIAA bulbs. have had them on my truck for over a year- one finally blew around nov. they are nice and very bright
Old Feb 17, 2009 | 12:31 PM
cquestad's Avatar
whats the cometic gasket run...I like the two piece design!
Old Feb 18, 2009 | 02:57 AM
D45's Avatar
D45
It is a great design, plus it makes it really easy for lining them up with the slots on the one side
The manifold gasket set and turbo flange gasket was around $70-$75 shipped.
FTE (Fast Track Enterprises) is where I bought mine, and highly recommend them!
Old Feb 27, 2009 | 11:17 PM
D45's Avatar
D45
Well, an unexpected purchase was made:
Main Website:
http://www.madselectronics.com/
Smarty POD:
http://www.madselectronics.com/Smarty06PoD.html
Smarty S-06 SR POD (Power On Demand)
SW # 0 : Half power
SW # 1 : 30 Hp increase, with added timing
SW # 2 : 60 Hp increase, no added timing
SW # 3 : 60 Hp increase, with added timing
SW # 4 : 90 Hp increase, no added timing
SW # 5 : 90 Hp increase, with added timing
SW # 6 : 130 Hp increase, no added timing
SW # 7 : 130 Hp increase, with added timing
SW # 8 : 170 Hp increase, no added timing
SW # 9 : 170 Hp increase, with added timing
I also have the Beta 4.2 and Beta 4.4 files I am going to try out.....see how long the stock trans holds up for!
Old Feb 28, 2009 | 12:40 AM
82NDSNPR's Avatar
your going to have a sweet ride im jelous that vc is the chit almost hate to put it under the hood you need to cut a section of the hood off and use clear plex so ppl can see into the engine great job man hope mine looks as good when i finaly get the parts in the shop and start the install
Old Mar 4, 2009 | 06:55 PM
D45's Avatar
D45
Now for a simple, cheap, and easy upgrade.......I always thought the stock tcase lever was too low.
I had to lean forward and take my eye slightly off the road.
I learned that some Jeep's tcase levers use the same thread pitch/pattern (M10x1.5mm) as my truck. Jeep owners use this extension piece after a body lift is installed.
I bought a bare aluminum off Ebay for $10, scuffed up the finish and used some epoxy paint.
You also also buy them prepainted from Quadratec:
http://www.quadratec.com/products/96117_500.htm
Pop the ****'s top cap off, use a socket to remove the nut (metric, dont recall the size) and unscrew the **** from the post. I thought the **** was held in place by the nut, it is also screwed on tightly.
Stock:
Reinstall everything and voila!......very comfortable height, at a great level to use.
Old Mar 4, 2009 | 07:02 PM
mikmaze's Avatar
lookin good, on the bulbs tho, take the 9006 fogs back and get the 9005's, remove stock fog bulb, compare with base connector for 9006, remove rib to allow use of 9005 bulb in place of the 9006 bulb, 20 watts more light, for the same price !
Old Mar 5, 2009 | 12:43 PM
D45's Avatar
D45
I installed the POD yesterday, and it feels 'good'......
I used SW # 7 : 130 Hp increase, with added timing
I adjusted the tires size and read any DTC (none thankfully!)
I put it on power level 60, 80, and finally 99.
It seems good, just not great......hard to explain.
Torque Management I used # 2 - Mild
Injection Timing I used #2 - for stock injectors
Rail pressure I used # 2 - Mild
Maybe it is just hurting for some more fuel. The AD150 will be installed around the 16TH......
Old Mar 5, 2009 | 03:37 PM
UNDER-PRESSURE's Avatar
Might be time for a little more air also?
Old Mar 6, 2009 | 05:39 AM
D45's Avatar
D45
The AD150 is the main priority on the list right now, which will hopefully be installed and completed by the end of the month.
I have the ATS Manifold Pulse Flow at the powdercoating shop right now and then I will have to fund a new aftermarket turbo......to help flow more air.
I am fairly confident the S&B air filter on my Icebox intake will flow more than enough air, just need a better turbo.
Old Mar 6, 2009 | 03:48 PM
82NDSNPR's Avatar
even with an airdog if you have after market sticks the smarty will eat all the fuel and leave your rail dry
Old Mar 6, 2009 | 04:26 PM
D45's Avatar
D45
I am going to leave the stock injectors in for a while.....
Old Mar 8, 2009 | 09:52 AM
iceboxmfg's Avatar
Hey D45, it looking pretty good! Are the flames on the valve cover painted or airbrushed?
