bully dog issues?
Old Jan 8, 2015 | 10:02 AM
sabre's Avatar
bully dog issues?
Hey ...I'm new 2 the site and I have an 06 3500.....I bought an edge cs tuner that won't communicate with my truck ...I caked edge and they said it's cuz I tried my friends bullydog gt out b4 buying and they said when u reset your truck back 2 stock the bd leaves something behind ....so I either trade my edge in for a bd or get my truck flashed ....anyone else ever heard of or experienced this ....the bd says it resets to stock but I'm sure they wouldn't advertise that it leaves a code behind anyway
Old Jan 8, 2015 | 01:08 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Yep.....this happens from time to time
Old Jan 9, 2015 | 12:30 PM
sabre's Avatar
There's no other way around flashing the truck ...I just don't want 2 waste money on something I don't need 2 do is all ....just seems odd it doesn't totally remove itself but works on another vehicle
Old Jan 12, 2015 | 06:53 AM
MikeyB's Avatar
Did you change any other parameters or options like the tire size? If so I believe the parameters have to manually set back to stock with the Bullydog before proceeding.
Old Jan 12, 2015 | 11:34 AM
sabre's Avatar
No nothing was changed as far as I remember cuz I remember I only used it for a week but I'll look into it ...thanks
Old Jan 12, 2015 | 07:07 PM
sabre's Avatar
On another note ...my trucks having issues starting now after 160k. ..and I know it's got a grid instead of plugs but any info on the best spot 2 start looking 2 resolve the problem would be great
Old Jan 14, 2015 | 07:02 AM
MikeyB's Avatar
Bullydog in the past has used non US spec firmware which after going back to stock other programmers will not recognize (I assume is what happened to your truck). So your options would be going to the dealer for a reflash and starting fresh, or buying a Smarty and having them install a special recovery file to blast your ECM with the correct US spec firmware.
Old Apr 1, 2015 | 07:24 PM
sabre's Avatar
06 Cummins issues starting
Can anyone give me a good place 2 start looking into fixing my glow grid ...the beast is laboring 2 start if it's not plugged in period warm or cold ...heard there's relays that r a good cheaper place 2 start but not sure how many there r or which 2 try 1st
Old Apr 1, 2015 | 09:19 PM
rockcrawler304's Avatar
It's not your grid heater. Not sure what it might be but the grid heater is not the issue.
CLeger67
Apr 7, 2008 08:17 AM
chevkiller
16
Feb 16, 2004 01:14 PM
Push Rod
Feb 8, 2003 07:51 PM
