Bully Dog Fuel Pressure
Does the Bully Dog Power Pup Triple Dog increase the fuel pressure when in the performance mode? I have heard different stories some say yes, some say no. I installed the downloader this weekend, and would like to just leave it in the middle performance setting all the time, but I dont want to do any long term damage to my engine. I have EGT, and boost gauges installed so I can monitor things, especially when towing. I will occasionally pull about 12K behind the truck, and I will back the downloader down only if needed then. I have a Aeroturbine 4040L, and Diesel Power Products Cool Hose ordered, which I hope to have installed in the next few days. I really dont plan on doing much else to the engine as I dont want to get crazy with it, and tear it up.
2005 CC Dually, Silver SLT, 600, G56 6spd., BDPP, Muffler and Cool Hose on the way
Only way to verify is with a SPA gauge, or the upcoming SP Diesel box with a rail pressure display. I know I'll be getting one or the other asap. After talking with Bullydog, I think they just tell you what you want to hear. They also told me that they fixed the P0633 code for the trucks with a grey key. Not so, mine still threw it when I installed the downloader.
Seeing as they took the part of their website down that claimed the D/L stored all your factory settings, I bet that wasn't true either.
That being said, I'm happy with the mild performance gains the D/L gave me. Much smoother than some other modules I've tried.
I think the BDDL does pressure in Perf and Extreme, but only when you're really laying on it. One of the things that sets the BDDL apart from a lot of pressure boxes is that it runs close to stock rail pressure when you're cruising on the highway. I know the EZ cranks the pressure up even at idle on level 4 (and I think the other levels, I can't remember) and during cruise. That's why DonM seems erosion on the injectors that have had pressure boxes.
At least with my tripledog on my 555 I leave it on extreme at all times. I can't get it to hit 1300F until I'm going about 110mph after ripping on it to get there. I couldn't do it trailering 4000lbs, either.
I stacked it with the EZ for a week... holy crap that was an awesome ride! Idle was funny though, you could hear the rail pressure fluctuations changing the injector clatter so I yanked the EZ. OK that was OT.
Andy
Andy
Andy
Andy
I suppose your mileage may vary and I don't have my FP gauge on yet but the truck seems to have enough fuel to use the EZ. I do have the boost elbow from the EZ installed so that lowers the EGT's a bit I'm sure. It sets an overboost code with just the elbow and no boxes installed (no downloader either) so it must be doing something
I don't think a FASS is the answer but it wouldn't hurt to get a high flow pump and ditch the stocker.
Andy
Andy
I installed the Aero-Turbine 4040, Cool Hose, and removed the silencer ring from the turbo this past Tues. The truck sounds great now, exhaust note is just about right for me. It is a little louder than stock, but has a deep tone like a big cube engine. Interior noise on the highway is well within acceptable limits, and I can carry on a normal conversation without having to yell, or go "what" every 3 seconds. I love the turbo noise now, but I have been into drag racing, and tractor pulling for years, so I may be biased on that one. I have picked up 1 to 2 mpg since adding the muffler, and Cool Hose . I had originally lost about 1/2 to 1 mpg at 65 mph after installing the BDTDPP, but the extra power was worth it. Since the Bully Dog's installation, I have ran it exclusively in the middle performance setting. Right now the truck is getting between 21.5 and 22 mpg at 65 mph, and it only has 1500 miles on it, so I am very pleased about that.
2005 DRW 3500 QC SLT, Silver, 600, G56 6spd, BDPPTD, Aero-Turbine 4040, DPP Cool Hose
I cked. by hand calculator at the 3rd fillup, which it still has just over a half tank right now at 1500 miles. The overhead in mine so far has been pretty accurate, but I will recheck by hand at next couple of fillups. I do 90% of my driving on the highway, and shift around 2000 rpm with a light foot when I'm going for mileage. I know a guy with a 2004, QC SB 2500 getting 23 to 24 mpg. His truck is a bone stock 6 spd with around 35,000 miles on it. Seeing the mileage on his truck was one reason I traded in my 96 F350 CC dually Pwr.Strk./ Auto ( 15 to 16 mpg )for the new truck. Both of our trucks are 2WD which helps a little.
Originally Posted by abc4yew
Loco, Is that mileage hand calculated or by the overhead, That would be the best mileage ever recorded in a 3rd gen. ks
Guys, You 2wd standards make me wish I lived in a pavement world all the time. I've been out of 4x4 only to make the 500 foot journey from the logging road to my house in the last 3 weeks. Tis the muddy season. The only good thing is that I haven't gone to far so I'm still on the same tank. To have such self restraint. I'm averaging 15mpg with all this 4x4 in mud and rain. ks
Guest
Posts: n/a
how can I tell if the rail pressure relief valve has been open or been opening. I've been running the bdpp on extreme and the EZ on 2 with the boost elbow installed for the last couple of months with no problems. Runs smooth other than a real touchy throttle at low RPMs, it'll roll the smoke but as soon as the turbo spools up, it totally clears up. AND the highest EGT I've seen is 1175-maybe1200 degrees pre-turbo and that was a full throttle run from 40-105. I'm really suprised it runs as cool as it does, not sure if it's a combination of the boost elbow and the 4" shorty straight pipe exhaust or what. So, i was just wondering how I could check the rail pressure relief valve for any damage, because it drives totally fine (haven't noticed any extra idle clatter or anything like that either).
CLeger67
04-07-2008 08:17 AM
chevkiller
16
02-16-2004 01:14 PM
Push Rod
02-08-2003 07:51 PM
