boost gauge
Old May 20, 2006 | 07:07 PM
buckhunter's Avatar
Question boost gauge
i just started doing upgrades to my truck, noticed that boost gauge was installed post turbo, is that giving me a truer readout or should it be installed pre turbo?
Old May 20, 2006 | 08:57 PM
blord's Avatar
Definitely needs to be on the "hot" side. Just like measuring voltage, you can't measure it on the "cold" side.
Old May 20, 2006 | 08:58 PM
If your boost gauge was installed pre turbo you would never see any boost.
Old May 21, 2006 | 02:07 AM
SSminnow's Avatar
I am assuming you are refering to an EGT gauge, maybe??? If so, then pre turbo in the exahust manifold is where the exhaust probe needs to be for a truer reading. If post turbo, hard to tell how hot it is BEFORE the exhaust gets to the turbo, and maybe a little to late cathc a meltdown.
If you ARE talking about a boost gauge, it would HAVE to be post turbo to get a reading, as mounted PRE turbo would give a vacuum reading.
Maybe you are talking about post INTERCOOLER and pre INTERCOOLER? If so, you would need to be POST intercooler for a more true reading of what your motor is seeing boost wise, because if mounted PRE intercooler, you will get a higher boost reading before it goes through the intercooler and tehn into the engine, and give you a less accurate reading.
How's that?
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
