boost fitting question with htt turbo
Old Mar 7, 2008 | 09:03 PM
Dwitt0187's Avatar
is there a problem with using a boost fitting that comes with the edge ez. i want to put it in my htb2 to make higher boost levels and dont want to take the turbo off to adjust the wastgate linkage. there is no why i can get to the rod with it on the truck so please give me some opions
danny
Old Mar 7, 2008 | 09:38 PM
Dwitt0187's Avatar
im gonna go ahead and put it in some tell me if im going to blow something apart or if boost level will be to high for stock head bolts
Old Mar 8, 2008 | 12:12 AM
stock600's Avatar
Let us know how it works out.
Old Mar 8, 2008 | 04:50 AM
homewrecker's Avatar
I ran one on my 62/12. I shortened the rod as short as it would go and could still only get 38-40lbs.With the elbow(edge type) I could get 43-45lbs.When I installed the flux1's I had to remove the elbow to keep the boost under 50lbs.I ended up running the rod back out and still couldn't keep it from hitting 50lbs.Thats why I upgraded to the 62/13ss/71.I can hold 48lbs with it the way it came out of the box.
I would think with 90hp injectors you would have no problem getting it to spool well past 40lbs.Don't think the 14 exhaust housing would cause that much difference.You never did say what kind of boost you are making.
You can get the snap ring off with some 90* snap ring pliers.Just have a couple extra rings laying around.Gettting it off is easy,getting it on is ackward.I dropped a couple and never found them.I had a bag full though(from Lowes and they are cheap) and finally got it on.
Old Mar 8, 2008 | 07:02 AM
Dwitt0187's Avatar
i haven't been able to drive the truck hard we just got 8 inches of snow here so there is no where to get traction to build any boost i was making 37-40 lbs of boost without it.
Old Mar 8, 2008 | 07:58 AM
wvtruckpuller's Avatar
Over a year and no problems yet.Be carefull not to wind it in to tight.
Old Mar 8, 2008 | 09:12 AM
Dwitt0187's Avatar
did help the boost level very much
Old Mar 8, 2008 | 10:41 AM
Yes, I had the set screw to tight at first and it burried my 60 lb guage.I backed it off 1 1/2 turns and now its a steady 55.
Old Mar 9, 2008 | 10:27 AM
Dwitt0187's Avatar
i havent had a chance to let it completly go yet but at about 3/4 throttle i did hit 47 lbs of boost and was climbling when i came out of it
O.T
16
Jan 14, 2008 02:47 PM
moparmatt
Apr 25, 2007 02:13 PM
Bobcat698
Nov 8, 2006 11:20 AM
RAMROD2006
Oct 25, 2006 07:57 PM
SSweeney
Jul 1, 2006 08:49 PM
