boost elbow question
Old Jul 9, 2005 | 06:39 PM
Smokeitup's Avatar
If I install a boost elbow on my 04 with the predator module will this in turn make it fuel more, less or just stay the same but with a increase in my boost? I am not quite sure how the electronics work on the new models as my last truck was a 98 12V
Old Jul 9, 2005 | 07:33 PM
Smokeitup's Avatar
Is this the same as blocking off the wastegate?
Old Jul 10, 2005 | 02:08 PM
pcburnout's Avatar
A boost elbow only holds wastegate gate closed longer to raise boost levels.
and could be death for stock turbo with one good bark!
Old Jul 11, 2005 | 12:15 AM
Smokeitup's Avatar
what exactly does the bark do to the turbo and how easy is it to create this bark?
Old Jul 11, 2005 | 12:25 AM
BigBlueDodge's Avatar
beware of the boost elbow. Make sure you have a boost gauge if you intend on installing. Like pcburnout said, its designed to up your boost before the wastegate kicks in. From my understanding, barking the turbo is hard on the shaft, and its simply best not to be done. Basically, you do it by going WOT and then just letting off the pedal. The sudden decrease in airflow will cause the turbo to bark. This is predominately seen on high HP engines who can rev the snot out of the turbo. Someone please correct if I am misguiden.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
