boost elbow question
Old Jan 27, 2008 | 12:05 PM
RJ285's Avatar
Hey guys, I am looking to get a boost elbow for my stock turbo. Can I find these at a local hardware store or are these a custom made, must order online type of thing? If you can find it locally, what are the dimensions, ie. size pipe thread, length of male hose connector, etc.
Thanks
Old Jan 27, 2008 | 12:28 PM
MikeyB's Avatar
You can make your own by drilling the end of the stock boost elbow and threading a set screw.
Or you can buy one off of ebay for around $20 like I did.
MikeyB
Old Jan 27, 2008 | 12:40 PM
RJ285's Avatar
So I can't pick one of these up at home depot or equivelant?
Old Jan 27, 2008 | 12:46 PM
MikeyB's Avatar
Don't think so. You can get a set screw from there though.
Here's one on ebay. http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
MikeyB
Old Jan 27, 2008 | 12:53 PM
RJ285's Avatar
Alright. Thanks for the help Mike. I was just feeling bored and thought that this would be a project I could get done today yet, but not if I can't get the part.
Old Jan 27, 2008 | 01:13 PM
soulezoo's Avatar
DTR 1st Sergeant
If you already have the tap, set screw, drill bit... It takes all of about 20 minutes to do.
For the time it would take to go to the hardware store to get the "part", and install it, you are only adding the time to drill and tap the existing elbow which is less than 5 minutes.
Old Jan 27, 2008 | 01:22 PM
cbrahs's Avatar
( Will not work on 2001-2002 auto trans with turbo part # 3592811 or 04.5,05,06,07,08 trucks ) copied from the ad on ebay
does it work on any of them! LOL....
Old Jan 27, 2008 | 07:46 PM
stealman1's Avatar
I would like to know how you set it? Not physically, but how much psi and how do you know when it is there? Does that make any sense?
Old Jan 27, 2008 | 07:55 PM
MikeyB's Avatar
Need a boost gauge.
MikeyB
Old Jan 28, 2008 | 10:13 AM
stealman1's Avatar
Ive got one. So I just keep adjusting until I see my gauge go to 32psi? The gauge moves fast and wont stay at peak for long. Seems kinda hard to tell.
Old Jan 28, 2008 | 10:23 AM
MikeyB's Avatar
Yes. But are you running some type of performance box or programmer?
MikeyB
Old Jan 28, 2008 | 10:51 AM
soulezoo's Avatar
DTR 1st Sergeant
The best and most accurate way I know of is to remove the boost elbow, attach to air gun off air compressor, set air compressor regulator to desired psi you wish wastegate to open, attach the hose going to the wastegate actuator, cycle the air gun off/on while adjusting the set screw until wastegate actuator no longer opens, then back off set screw until it does open and function reliably... reinstall boost elbow.
Old Feb 29, 2008 | 10:26 AM
5.9Toy's Avatar
got one
Thanks
I have my stock one off my truck 04 dodge 3500,I put the edge one they gave me in there and took my stocker out email me if you need it
Old Feb 29, 2008 | 07:55 PM
holeshotking1's Avatar
I didnt tap any thing i went to home depot bought a t handle set screw like the kind on evaporative coolers on houses put 2 male fitting on either side and cut the rubber hose between the turbo and waste gate, installed.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
