Boost Elbow
Old Jun 12, 2007 | 06:49 PM
2003Ram's Avatar
Originally Posted by lniemeyer2
I thought on the 03-04's that all the boost elbow did was increase egt's and that the extra amount of boost wasn't benificial it just blew hotter air.
As you can tell by my reported EGTs, thats not true. In fact, the stock turbo is efficient to about 36psi.
Old Jun 12, 2007 | 10:59 PM
lniemeyer2's Avatar
That's right, it was for anything over approx 35 psi where the turbo acts as a heater and having a neg impact on things. You also need some sort of boost fooling devise when you add an elbow or you will probably throw the overboost code.
Now I remember why I took mine off, I hit about 30psi with the stock elbow and when I had my edge elbow installed I would peg out my 35psi guage.
Old Jun 13, 2007 | 09:56 AM
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by Rob C
Try pulling the boost fooler out and see what happens, I have pretty much the same set up and I get 34-36 psi out of mine.
I have done so and tinkered around with different things. I've seen 1 (only one! and with the boost fooler) spike of 30... but other than that I've only seen the spike of 25-26 and steady boost of 22-23.
Old Jun 13, 2007 | 12:17 PM
Rob C's Avatar
Have you tried clamping off the wastegate line? if so, then I would be questioning either the turbo, or a turbo leak. You may want to pull the turbo out and do an inspection to see if anything is wrong.
Old Jun 13, 2007 | 12:41 PM
soulezoo's Avatar
DTR 1st Sergeant
I have tried clamping the line... heck, I've plugged it too... I have inspected for leaks and found none. The turbo shaft is still pretty solid too. I am thinking it might be the waste gate blowing off early.
Old Jun 14, 2007 | 10:13 AM
Rob C's Avatar
If you clamped it off, or plugged the line, this means you have isolated the wastegate from the system and any chance of it leaking off boost and if it still wouldn't produce boost, then there is something wrong with the turbo, you have a leak some where, or your boost gauge is bad.
dodgediesel
14
Dec 14, 2006 09:54 AM
TorqueJunkie
15
Aug 30, 2006 09:15 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
triplenickel
Aug 23, 2005 04:01 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
