Blew a freeze plug, Easy Fix?
Old Sep 29, 2008 | 07:02 PM
Brian Lent's Avatar
Has anyone had to replace the freeze plug on the rear above the bell housing? I hope I can get it in if I take off the down pipe and get it from the bottom. Also what size do I need?
Old Sep 29, 2008 | 07:16 PM
Brian Lent's Avatar
Anyone had this prob?
Old Sep 29, 2008 | 07:28 PM
TonyB's Avatar
I have read about it...Someone, can't recall who, has a pattern for aluminum blank off to reinforce the plug so it stays in. You may want to try a search.
Tony
Old Sep 29, 2008 | 07:32 PM
cumminsdriver635's Avatar
Hailsey machine makes a kit that will fix it for good.
You dont have to take anything off either. It pushes into the back of the block(you can do it with one hand), and then has 3 bolts to hold it in. It'll never blow out and is easy to put in. I dont think it is real expensive, and i dont think it is listed on their site, but call them and ask them about it.
Eric
MikeyB's Avatar
Somewhat common for the early 600's blowing freeze plugs.
Here's one thread. https://www.dieseltruckresource.com/...ht=freeze+plug
Can do a search for 'freeze plug' in the 3rd gen engine section for a lot more info.
MikeyB
Old Sep 29, 2008 | 10:04 PM
J Lent's Avatar
How'd you do that? You must be a idiot! You should listen to your brother next time.
Old Sep 29, 2008 | 10:30 PM
trx's Avatar
trx
I think it was Dodgezilla 04 who had a pattern to cure that problem.
Old Sep 29, 2008 | 11:23 PM
J Lent's Avatar
Anyone know the size of that freeze plug?
Old Sep 30, 2008 | 12:04 AM
jlibert's Avatar
Link to write up I did on comp D...
http://competitiondiesel.com/forums/...reeze+plug+fix
Old Sep 30, 2008 | 06:48 AM
Brian Lent's Avatar
Thank you for the great article. Glad to hear I don't have to drop the tranny.
royta
Nov 25, 2016 11:48 AM
doug60
17
Aug 24, 2007 08:43 AM
jlibert
16
Jun 21, 2007 11:24 AM
dodgezilla04
78
Apr 28, 2007 02:42 AM
Stamey
Feb 23, 2007 07:27 AM
