"Big Rig" Tire and wheel idea for SRW...
Old Apr 20, 2006 | 06:35 AM
  #31
Patrick Campbell's Avatar
Originally Posted by tweeter
The ricksons are beautiful, but the cost to just get them up here is just plain silly, plus exchange, tax, and brokerage....ouch. I got a quote for a set and by the time all was said and done it came out to $4400.00
If 19.5's are $4400 how much are 22.5's going to be? Most likely cant be cheaper... and they are much more logical. Can't you have someone in the states hold onto them... then you can bolt them up and drive home with them on ...
"What new wheels?"
Old Apr 20, 2006 | 08:55 AM
  #32
Big Horn's Avatar
22.5's with adapters is about 2600.00 from chromewheel.com. I guess thats not to bad compared with 4400.00 for 19.5's. I guess that tire wear is much better with the 22.5's also. Almost double from what I've heard.
Old Apr 20, 2006 | 09:06 AM
  #33
monsterB's Avatar
Ad removed site violation
Old Apr 20, 2006 | 09:08 AM
  #34
monsterB's Avatar
Old Apr 20, 2006 | 10:31 AM
  #35
2600 for what? What kind of wheels? What kind of adapters? what kind of tires?
4400 was for forged alloy wheels with tires with shipping and taxes to canada, I'm pretty sure...
Old Apr 22, 2006 | 01:13 PM
  #36
Big Horn's Avatar
2600 was for the 22.5 alcoa floatation wheels, with lug nut covers and center caps. And the 8 to 10 lug adapters needed to bolt these wheels to our trucks. I don't think that this included shipping. I priced a set of tires from the local les schwab, toyo 255/70/22.5's were about 255.00 each.
Old Apr 23, 2006 | 12:14 AM
  #37
Ripper01's Avatar
$2400 with tires for 19.5" from les schwab... Went got a quote today for vision type 81 wheels and some kind of agressive tires... 245/70r19.5 tires.. i might be going this way i jus need a job first so i can get some cash...
Old Apr 23, 2006 | 07:40 AM
  #38
There you go. We do not have les schwab out here. Rickson sells Les Schwab wheels for like $50 more per wheel than Les Schwab or DiscountTire. Convenient.
Old Apr 23, 2006 | 09:30 AM
  #39
derek840378's Avatar
iker42, 265 etc has nothing to do with the rim, its the width of the tire in millimeters. So a 315/70r17 is 315 mm wide (11.93"), the side wall is 70% of the width (8.35"). 11.93 + 8.35 + 8.35 = 33.7" tall tire, mathematically anyway.
sorry u dont add the sidewall hight to the tread width. its 2 X sidewall hight + wheel size. 2(8.35) + 17 = 33.7 you did the wrong math but somehow got the right answer
Old Apr 23, 2006 | 09:32 AM
  #40
Originally Posted by Tiny Ram
A true "super single" are going to be way too big for a stock height truck. The smallest tire i've seen is 385/65/22.5 which is 42" tall.
You would probably be better off running a regular 22.5 with a wider offset and try to find a more normal size tire.
http://www.chromewheel.com/PIX/ram2500.htm
It would be a hard fit, but IMO the 385's would look awesome on a 3rd gen. I'm gonna try to make it work
stockton wheel used to make a 16" super single. not sure how big of a tire you'll need, but a 315/75/16 might work
Old May 7, 2006 | 06:51 PM
  #41
D.Wiggs's Avatar
On the American Force website they show a stock heigh F-350 with 22.5" and "traction tires". Any idea what kind of tires they are?
I plan on running a 22.5" wheel with as wide a tire as possible and no lift. I will let you guys know if any cutting is involved. My truck is an '06 Megacab 3500 DRW 4x4.
Old May 8, 2006 | 12:45 AM
  #42
smokey196240's Avatar
would like to see a pic of a set of them on a 06 dully.
Old May 8, 2006 | 12:48 AM
  #43
D.Wiggs's Avatar
You will on mine if all works out and they do not require a lift!
Old May 8, 2006 | 02:15 AM
  #44
Ripper01's Avatar
Heres what itll look like almost itll look a lot better on the megacab... It say you can run them with a stock height dodge dually you should give them a call an ask them some of the questions youll prolly get a better more difinitive answer
Old May 9, 2006 | 02:01 PM
  #45
keeping this thread alive want to see a super wide rear on a dodge
totalloser
Mar 20, 2011 11:55 PM
rcts
Nov 21, 2009 11:29 AM
kiszka6911
Mar 15, 2007 09:02 PM
Begle1
Jul 13, 2005 04:13 PM
Dieseldude4x4
Oct 17, 2004 11:07 PM
