BHAF!!! Wow! Huge!
BHAF!!! Wow! Huge!
I ordered a DuraLite BHAF yesterday and it arrived today at work... man this thing is huge. I showed it to a co-worker and he asked if I had to pull out a seat to get that thing to fit... hehe. I know they call 'em BHAF's, but I was still a bit shocked at the actual size in real-life... phew.
How much would you all estimate that this will drop EGT's w/Torque Tube?
Now, I'm going to order up a Xzillaraider Race Box and some guages... This Cummins bombing is a blast! I feel like a little kid! This thing should tow the '87 Collins 5'er I picked up last weekend no problem.
Jeff
Jeff
Originally posted by Dodgezilla
My hood hits mine when I close it. Who cares? It looks cool.....
Originally posted by Hoss
Pictures? I'm making the switch to BHAF soon and I haven't decided for sure how to stick it in there.
ask and you shall recieve
nickleinonen, I like the way you have yours setup... I'll be doing mine the same as soon at the Torque Tube shows up. Did you notice a significant drop in your EGT's after installing the BHAF?
Jeff
Jeff
i think i had about a 50° degree drop when i first put in the filter [while reusing the oem piping - first version i had] and i got about another 100° when i changed the piping... i don't know exactally how accurate is it, as the weather on the days i did my "test" drives was different, but right now at full load in 5th or 6th, i seem to top out at about 1100°
Let me add that mine hits the hood now because I cut the walls off the airbox and reinstalled it to keep road spray off of the filter. I got scared a couple of times when I had to drive through some high water. Now the filter sits on top of the airbox and it's about a half inch higher than before and the hood barely hits it but it's enough where I have wore a couple holes in the Outerwears cover and had to put duct tape on it!!
I installed mine along with my 4" downpipe and my temps dropped about 100 degrees. I'm not sure which helped the most though...
I like that setup you have Nick but I'm not spending any more money on my system just to get that extra turn.. Good idea though....
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
