Bhaf
Old Jul 22, 2005 | 10:42 AM
appydriver's Avatar
Question Bhaf
Where can I puchase this filter and what sort of adapters or fittings will I need? Thanks
Old Jul 22, 2005 | 07:04 PM
nickleinonen's Avatar
the filter can be ordered from any napa... the piping can be had from airflow systems inc. you might find the piping locally if you search around the truck shops.
Old Jul 22, 2005 | 07:32 PM
Dodgezilla's Avatar
Actually you don't need any new piping to run just the filter. The rubber boot that connects to the airbox will slip over the inlet of the BHAF but it is a really tight fit. Then you just have to remove the air box and relocate the air temp sensor....
Old Jul 26, 2005 | 07:15 PM
kertoncol's Avatar
Have any of you had problems with the BHAF getting wet when it rains or through puddles? Do you really notice an increase in airflow and power? Has it helped your EGT's?
Old Jul 26, 2005 | 07:28 PM
Dodgezilla's Avatar
Most of us run an Outerwears Water repellant cover to protect the filter. I went a step further and just cut all the walls off of my airbox and then put the base back on the truck. The filter rests on top of it and it protects it from the roadspray somewhat.. I've driven through some high water a couple times and have had no problems. I did not drive like an idiot though.... If you're currently running a stock filter setup you will probably see a difference in your EGTs. It won't be much but anything is better than nothing. You probably won't feel any difference in power but the turbo will sing a bit louder.
Feb 22, 2024 07:16 AM
Rickcher
Sep 2, 2009 05:08 PM
Marine
113
Nov 6, 2007 06:24 PM
Ace
Oct 31, 2007 06:46 PM
