best programmer for 04
Hello
looking for a programmer for my new 2004 2500 hd ,truck is all stock ,do some towing now and then what's gives the best performance and keeps the tranny in one piece .
thanks
Bor
thanks
Bor
first thing you need to do is figure out if you have an 04, or an 04.5......... on the drivers side of the "valvecover" is a sticker, with rated hp, if it says rated 325 hp you have a 2004.5 model, and choices can be quite different than that for an 04 truck, the o4 will 9 times out of 10 get better fuel mileage.
It says ISB 325 so it's a 04.5
That's good - you have 4" exh. and a better turbo than the 03-04.4 305s. I love my Diablo Predator. The tow tune is 60 hp but it's only a teaser. The 100 hp is also the economy tune and it's perfect for towing and street and it does some tq. mgnt. below ~1500 rpm to save the drivetrain. My egt maxxes at ~1225 so I don't have to worry about heat. It also has crazy wild tunes, if you dare! The U7130 Predator is for 03-05. I don't know why it works on early 325s and not late ones. Craig
confusion
I am a little confused ,we looked ad my truck today and also take a look ad the 2003 my friend have and the turbo's look the same ,he told me that the 325 have a electronic controled waste gate and the 305's a mechanical one.
my engine sticker say it's a isb 325 but have a mechanical waste gate maybe the changed the valve cover or something ,anybody who can clear something out ,I want to know for sure so I buy the right programmer and don't want to mess up the ecm .
thanks
bor
thanks
bor
Yea the 04.5 and up will have the HE351 instead of the 341, 351 has the electronic boost sensor, way better turbo 60/60/9, if i rem right. If you wanna keep it safe look into the edge ez, sold the smarty and bought one of those for mine and couldn't be happier!
Maybe it isn't a stock turbo? Did you buy the truck new? Look though the passenger side wheel well at the side of the turbo. There should be a manufacturers plate that could tell you what it is if it's aftermarket. Either way, you need a programmer for an 04.5.
I found the electronic waste gate so it's a 04,5
After a lot of brainstorming and treid the diablo sport of a friend of mine decided to go for the smarty s-06 POD due to the fact you can chance the tq management .
Got the smarty today and loaded #5 wich is a real differents whit the diablo on extreme ,love the smarty allready after 1 hour !!
Thanks for the input ,I will saving some money for the trans !
cowboy717
Aug 25, 2006 01:35 PM
bigman
16
Aug 25, 2006 07:00 AM
ptgarcia
Apr 15, 2006 09:01 AM
G-NOTE
13
Aug 16, 2005 02:03 PM
