been saving, Now what
Old Jan 15, 2007 | 05:11 AM
dditt0635004x4's Avatar
you can see from my sig. what i have now. I was satisfied at first but now it's not near enough i've been on 7 14's for 3 weeks now and got ten more to go. i know the tranny is a most but any opionions on anythings else. i was thinking twins and nitrous or a new single? what do you guys think?
Old Jan 15, 2007 | 10:00 AM
SSminnow's Avatar
I would upgrade the Lift Pump (I went with Glacier 392, great fuel system) and a fuel pressure gauge to monitor.
What I have done is start out with:
BDPP, and a 4" exhaust with pyro and boost gauges (I have a 6 speed)
I then added a Big Line kit from the fuel filter housing to the CP3 with a fuel pressure gauge, and that is when I found out my lift pump was on it's way out.
I then added the GSL 392 kit from Glacier and running 20 PSI to the CP3.
I am now waiting for my TST Powermax CR R49AP to stack with the BDPP. The R49AP gives me the change on the fly, a crap load of adjustability, gauges, including Rail Pressure gauge and able to adjust the Rail Pressure among other things, including a program for a single, twins, fuel economy, standard program, adjust timing, and more.
I have also ordered a kit for an air intake in preperation for a SPS (the 66 is the one I am thinking of going with) and Injectors.
I MAY go with the 5" after that, depending on EGT's, as I am staying away from Nitrous, Meth, etc.....as I want to run on #2 only.
I like Nitrous (I run it on both of my race cars) but for a street car, having to fill bottles is a pain in the butt to me.
Old Jan 15, 2007 | 10:09 AM
ramtd02's Avatar
i would go with a upgraded lift pump, get a clutch,SBC or the like, then look at a turbo, for you mods a small single will do!! I recommend the II SPS6280. It is good up to 600 hp or something like that. Plus it spools much the same as a stocker!
Old Jan 15, 2007 | 01:28 PM
973604x4's Avatar
ditto! love my turbo.
Old Jan 15, 2007 | 07:51 PM
ya i would like to upgrade the lift pump and maybe a mp8 i'm really wanting to get in the 500 to 600 range, does anyone recommend a go deisel shop in this area i've been using 4wheel parts and am not to satisfied.
Old Jan 15, 2007 | 08:09 PM
973604x4's Avatar
I know some DFW shops but thats not very close....
Old Jan 15, 2007 | 08:45 PM
SSminnow's Avatar
What are you looking at to have done?
Old Jan 15, 2007 | 09:29 PM
i would like to have the lift pump mp8 turbo and clutch upgraded and possibly nitrous or propane
Old Jan 15, 2007 | 09:31 PM
SSminnow's Avatar
You have a PM
Old Jan 15, 2007 | 09:33 PM
i was also looking at putting injectors
Old Jan 15, 2007 | 09:36 PM
jmccart's Avatar
How is your clutch holding up? If it is slipping now, how far did you go before it started to slip? Clutch is always on the back of my mind since on my last truck, the superchips, exhaust, and intake were way too much for it to handle.
Thanx.
Old Jan 15, 2007 | 10:45 PM
i'll admit it im very hard on this truck and it stays on the crazy larry and i havent had a problem with the clutch yet "knock on wood"
Luke S
Apr 20, 2006 04:20 PM
redneckonthenet
Apr 5, 2005 08:25 PM
Jack Thorpe
Aug 14, 2003 11:27 AM
wannadiesel
Jun 10, 2003 05:21 PM
doug
Nov 14, 2002 09:09 PM
