bd tripledog versus quad ?????
Old Mar 22, 2011 | 09:49 AM
bullwhipjkg's Avatar
? is ive been running a quad 3 position chip for bout 80k miles been pleased with power and fuel milage 98% on 60 hp
just had my injectors changed and the guy said that the quad caused the injectors to go out because of the boosted fuel pressure so be it truck was smoking at idle put new inj. now its not
got a tripledog last nite just finished updating to lastest version so how will it compare set on tow with the low end power on also
to the quad on 60
thanks justin
what are the hp settings on the tripledog just the basic settings no CL
Old Mar 23, 2011 | 09:21 AM
tcr's Avatar
tcr
What tranny? I hated every tune BD had for my 03. I tried all the programs they had and the fueling was either weak or not at all linear. Good luck on a 305/555
Old Mar 23, 2011 | 12:43 PM
HotRodK's Avatar
Red face
Funny timing. Im STILL trying to get a smooth power delivery out of my Bully Dog. I just talked to a tech there today and he said they gave up on the 555 trucks long ago. I just now reinstalled the TD243. Its the latest version for our 555s. Mine has just never pulled clean up to redline with this tuner. It works nice with the extra low end, but has zero top end. If I dont use the extra low end, its a pig down low and still doesnt like to rev past 2500 at WOT. Cant figure out why...
Old Mar 23, 2011 | 10:01 PM
update
real touchy throttle down low seems to have power up to half throttle after that dead on top like mentioned
set on tow with the low end power setting
26 psi boost tops WOT less then 1400 egt WOT
the instant power is wow then starts to fade away
Old Mar 23, 2011 | 10:02 PM
no problem getting to 3 thousand plus RPMS
Old Mar 23, 2011 | 10:03 PM
auto tranny
Old Mar 23, 2011 | 10:42 PM
HotRodK's Avatar
Smile
After loading the TD243 tune again, the truck is running much better. I have it on extreme, for now, and it runs good. Not fast by any means, but it pulls nice and clean all the way to the shiftpoints. Its a start!
Old Mar 24, 2011 | 04:23 PM
turned the extra low end off and have to have the BD TD on extreme to really tell it has a programmer
WL.
20
Oct 15, 2007 08:41 PM
TX_Diesel
17
Apr 10, 2007 05:29 PM
BigDodge1
Dec 5, 2006 04:46 PM
rockittboy
May 9, 2006 11:01 PM
Booger
Apr 3, 2006 09:13 PM
