Banks and Bullydog DL?
Old Feb 25, 2005 | 05:06 PM
tcr's Avatar
tcr
From the sounds of you guys w/ BDDL's, and John R's burnouts, I think I'm going to grab a BDDL. If I keep the Banks set at 1 or 2 I should be ok, right? I would like to keep it due to its safety features and sensor capabilities. Are all the bugs worked out on these programmers?
Old Feb 25, 2005 | 08:36 PM
whamby's Avatar
My BDDL is great. I have had it on every setting no problems so far. It is also stacked with a Ramifier. But by itself it is impressive on extreme that is for sure. But the Ramifier is pretty impressive as well.
Old Feb 28, 2005 | 11:03 AM
tcr's Avatar
tcr
Can I get more input or opinions from you guys, since both of these controls deal w/ fuel pressures I want to cover all my bases. Thanks!
Old Feb 28, 2005 | 11:05 AM
cquestad's Avatar
I think that is a good stack with turbo and tranny upgrades. Maybe Performance mode on the BDDL and then play with the 1-4 or so settings on the Banks...
That way you will not do too much hp from pressure.
Old Feb 28, 2005 | 05:08 PM
tcr's Avatar
tcr
cquestad, thanks for the reply. Anyone else w/ any info would be much appreciated.
Old Mar 1, 2005 | 08:11 AM
jayrods600's Avatar
I have the bdpp and the banks six gun with speed loader stacked . it works well if you do it correctly. i have tried just about ever level on the two together. i currently use the tow mode on the bdpp and the banks on 6. I ran the bdpp on extreme and the banks on 3. But that through the rail pressure code on the banks.
LilBigd02
17
Feb 28, 2010 09:22 AM
Ph4tty
Apr 15, 2007 10:31 AM
Tuf-4x4
22
Dec 17, 2006 06:24 PM
codered
Sep 24, 2005 08:45 AM
royalnine
May 21, 2004 01:47 PM
