aurora shot a crap
10-4
running a nonwasted gated turbo plus nitrous will boom cause it will spike the turbo real hard. Example look up nobody's vid of it, 2 stages 2nd one was lil bigger and boom. It blew the exhaust turbine off the turbo completly.
With a wastegated turbo u can run a certain psi and spray it and not have an issue with it. With nitrous this way is just safer.
The later 3rd gen turbos are by far the best stockers Cummins ever used. I could see the A2K being an upgrade on a 1st, 2nd, or early 3rd gen but I doubt it moves more air than a later 3rd gen turbo.
Your Smarty can also disable the stock WG
No, but I have heard "It's not the size of the dog in the fight, it's the size of the fight in the dog".
I'm no turbo expert by any means, but I just don't see how a smaller compressor wheel is going to flow more air. Maybe more hot air with higher drive pressures.
jrussell
I've looked at the stock exhaust wheel a few times. The exhaust wheel is only part of the equation though. You also have to look at the compressor wheel and exhaust housing size to compare air flow.
Twice the air with a smaller compressor wheel just doesn't sound realistic. Why would anyone need a LARGER turbo if that was the case?
People generalize that bigger is better. If this were the case, and bigger makes more power, then why doesn't everybody use an S480 as a single replacement. There is a lot to be accomplished by using the right geometry when making wheels and housings.
If bigger isn't better then why are all the other aftermarket turbo's bigger than stock?
Cfm's
From what i have found, and im not sure if they are comparing the same stock turbo as what we have but it is the 35, ats says the stocker flows 555cfm. Ats is saying that the a2k flows 877cfm. And i thought they rated it at
9 hundred something cfm's but all i could find was the 877. Where is erik at ats when you need him?
Gwoody
14
Apr 2, 2005 01:53 AM
AK RAM
Sep 22, 2004 01:56 PM
jimjawz
Jul 8, 2004 05:55 PM
