ATTN: All DiProcol pyro owners, interesting info:
Old Jul 10, 2005 | 02:45 PM
John Rodriguez's Avatar
Tire Hater
Exclamation ATTN: All DiProcol pyro owners, interesting info:
Well, I had bought all DiProcol gauges, because they matched the dash, but I figured I might as well go to a "comp" pyro setup, and sprung for the autometer competition pyro and gauge. It seems the diprocol reads 200! degrees lower WOT, probably because it was such a slow-responding pyro. The hottest my truck would get WOT from 0-110 was 1,400 with the DiProcol, and with the autometer, I'm pegging 1,600 by the end of 3rd gear. DEFINETLY A BIT HOTTER. I suggest anyone who's modded and putting down some fuel to change to a fast-responding pyro. The AutoMeter is the only one I know of (140 retail I think on the "competition" pyro probe) + gauge. If there are any others out there, I'm not sure. But I can definetly tell you, I'm glad I made the switch. The new gauge literally follows your foot, as fast as you can ramp down that go-pedal, the pyro is right along with you. Even rev'ing in neutral, you can see it move with your foot.
Old Jul 10, 2005 | 02:46 PM
BigBlue's Avatar
My ISSPRO is the same way.
Old Jul 10, 2005 | 03:13 PM
Rod meyer's Avatar
How do you know your auto meter isn't 200 hotter?
DiPricol may read slower but I doubt it would be 200 off.
You may want to get one more pyro gauge now and see who is telling thr truth.
Old Jul 10, 2005 | 03:23 PM
Tire Hater
Well, personally I'd like to think I'm not running that hot, but then again I have over 550whp worth of fuel through the stock turbo, soooooooooooooo I don't really think I'm hitting 1,400 by 110. So that's how I know the AutoMeter isn't lying
Old Jul 11, 2005 | 09:47 AM
cquestad's Avatar
My TST pyro and my Diprocal pyro read almost the same...TST reacting slightley quicker than than the Diprocal...but the Diprocal is in a hottor spot.
I don't think the time difference it takes to measure will have an adverse effect... especially if you never let your gauge GET THAT HOT!
John...you need a turbo bad.
Old Jul 11, 2005 | 11:04 AM
TRAVIST's Avatar
My pricol reads just as fast as I can press or release the pedal. It reads almost to the degree with my boss's x-monitor that he is running. Mine looks just like a tach as I get on it and when I come off the pedal so not sure what you are saying by reading slow.
TRAVIST
Old Jul 11, 2005 | 12:25 PM
banshee's Avatar
Pricol has a skinny probe that reacts a lot faster than the standard fat probe. It definitely makes a difference in how fast the temps react when you get on it.
Old Jul 11, 2005 | 03:54 PM
Tire Hater
I don't know what probe you guys got, but mine was sheathed in metal top to bottom with a skinny, dare I say, nipple at the bottom. The Autometer actually has the temp probe, maybe 1.5mm accross sticking OUT of the body of the probe itself.
Old Jul 11, 2005 | 04:07 PM
MR4WLR's Avatar
I think what would really be the most usefull info would be a sensor on the manifold or turbo that actually measured the "heat soak". How hot are your parts really getting not just the gasses that pass thru.
Old Jul 11, 2005 | 04:22 PM
RamWheelsBy4's Avatar
Hmmm, I am going to have to pay close attention to my two pyros. One Autometer Ultra-Lite and the Edge Juice/Attitude pyro. I have only paid cursery attention to the numbers, but I think they are pretty close to the same, the digital display usually is a little behind the Autometer, but that is just digital coding lag.
Both sensors are in the manifold pre-turbo about an 1 1/2 inch apart.
Old Jul 11, 2005 | 04:25 PM
Tire Hater
Do you have the "competition" probe, or the stock autometer probe? I bought the gauge, tossed the stock pyro into the junk box, and then bought a 130 dollar PROBE for the autometer.
6spd05Dually
181
Feb 17, 2015 01:39 PM
Big Horn 06
26
Feb 20, 2012 07:11 PM
B.A.Ram
17
May 8, 2007 03:09 PM
Dang
18
Mar 27, 2007 01:52 PM
BigBRUNO4
Apr 28, 2006 08:59 PM
