DiProcol Pyro Problems
Old Mar 26, 2007 | 06:09 PM
Dang's Avatar
My first DiProcol Pyro would periodically start wandering around giving me all sorts of weird readings. I changed the power supply and checked the grounding and still had problems. The dealer switched it out with a "new" version and now after a couple of months it is doing the same thing.
Anyone else having these issues?
Old Mar 26, 2007 | 06:14 PM
DynoDynamicsNE's Avatar
I was getting ready to buy the DiProcol gauges. I hadn't heard anything bad about them, but if there are others having problems, I'll have to rethink which gauges to get.
Old Mar 26, 2007 | 07:16 PM
Fisherguy's Avatar
No problems with mine so far...
Old Mar 26, 2007 | 08:00 PM
fjbiker86's Avatar
ive only had mine on for about 4 months and no problems
Old Mar 26, 2007 | 08:04 PM
lmills's Avatar
you have it wired to switched source? It needs to be wired to a source that drops power when the ignition is off
Old Mar 26, 2007 | 08:05 PM
OldSmokey's Avatar
Mine has been doing the same thing. Thanks Imills ill have to give that a try too.
Old Mar 26, 2007 | 08:59 PM
53 willys's Avatar
my dipricol boost gauge is still rattling when I get on it
this is after getting the first one was warrantied....
I still like them tho
Old Mar 26, 2007 | 09:02 PM
Luvnacumns's Avatar
I liked the diprocol's but I also liked my autometer's. When I went to buy them my guy said that autometers come with a rubber to put on the bulb for different colors so I got the green to see how they looke compared to the factory lights??? Never know until you try right!!
Shane
Old Mar 26, 2007 | 09:40 PM
Fisherguy's Avatar
Mark, I thnk soemone said their rattle was caused by the tube virating against something inthe a-pillar, maybe try some tie wraps in there or something?
Old Mar 26, 2007 | 10:03 PM
dperf's Avatar
i am having the same issue. Had two gauges, changed the thermocouple, and changed power supply from two different keyed sources and still periodically have the same problems. when it occurs, i can shut the truck off and it will reset and work normally. it seems to happen more on longer trips(30+mins), versus shorter ones. as for the boost rattle, i had this as well, but easily fixed it by wire ties and some form of soft insulation. small plumbing pipe insulation i think.
BD
Old Mar 26, 2007 | 11:01 PM
UnrulyNFS's Avatar
Fixed my rattle with wire ties.
No problems with my gauge in well over a years use.
Old Mar 27, 2007 | 08:35 AM
Dang's Avatar
Thanks for the info on the Boost rattle, now I can fix that issue. As far as the Pyro goes, I have tried two different keyed power sources and it made no difference. I suppose I could relocate the ground and see what that does.
Old Mar 27, 2007 | 08:40 AM
P.J's Avatar
P.J
..............to the BATTERY. I bet your problems go away after that.
I haven't had any issues out of my gauges so far, I like them the same or a little more than the Isspros I had on my old truck.
Old Mar 27, 2007 | 09:50 AM
53 willys's Avatar
I guess I will try some zip ties ( it is already zip tied but I will tie them up better) after I get my 2 pod with a handle apiller mount
thanks for the tips guys
