DiProcol Pyro Problems
My first DiProcol Pyro would periodically start wandering around giving me all sorts of weird readings. I changed the power supply and checked the grounding and still had problems. The dealer switched it out with a "new" version and now after a couple of months it is doing the same thing.
Anyone else having these issues? |
I was getting ready to buy the DiProcol gauges. I hadn't heard anything bad about them, but if there are others having problems, I'll have to rethink which gauges to get.
No problems with mine so far...
I've had mine installed now for almost 2 years and I haven't had one problem. That's even after they fell a few times when I had the overhead mount:( [laugh]
ive only had mine on for about 4 months and no problems
you have it wired to switched source? It needs to be wired to a source that drops power when the ignition is off
Mine has been doing the same thing. Thanks Imills ill have to give that a try too.
my dipricol boost gauge is still rattling when I get on it[verymad]
this is after getting the first one was warrantied....[verymad] I still like them tho[laugh][duhhh] |
Originally Posted by 53 willys
(Post 1428418)
this is after getting the first one was warrantied....[verymad] I still like them tho[laugh][duhhh] I liked the diprocol's but I also liked my autometer's. When I went to buy them my guy said that autometers come with a rubber to put on the bulb for different colors so I got the green to see how they looke compared to the factory lights??? Never know until you try right!![duhhh] Shane |
Mark, I thnk soemone said their rattle was caused by the tube virating against something inthe a-pillar, maybe try some tie wraps in there or something?
Originally Posted by Dang
(Post 1428067)
Anyone else having these issues? BD |
Fixed my rattle with wire ties.
No problems with my gauge in well over a years use. |
Thanks for the info on the Boost rattle, now I can fix that issue. As far as the Pyro goes, I have tried two different keyed power sources and it made no difference. I suppose I could relocate the ground and see what that does.
(Post 1429146)
I haven't had any issues out of my gauges so far, I like them the same or a little more than the Isspros I had on my old truck. |
I guess I will try some zip ties ( it is already zip tied but I will tie them up better) after I get my 2 pod with a handle apiller mount:cool:
thanks for the tips guys[coffee] |
