anyone make their own twins setup
Has anyone made their own twin turbo setup on here. i really wanna put them on my truck and was wondering if it would be worth it to do it myself? i can fab up pretty much anything but just need some guidance on how to do it?
Would my he351 be good enough for one of the turbos?
It can be worth it, yes... starts with self satisfaction on the job done and etc.
Plenty of people use the he351 as a secondary; no worries there. Just select your bottom turbo of choice (most popular is a s400 variant) and proceed.
Rip Rook at source automotive has many of the necessary parts for you. Call him and he will make sure you get the proper v-band clamps, sort out the details (there are many!) and what not. good luck!
I made mine from scratch. I would have bought the pipes from Source Automotive but I wanted an external wastegate and I didn't want any silicone boots (all v-bands). If you don't care about the boots or if you want to use the internal wastegates I suggest using Rip's pipes. It makes things a lot easier to fab up. I like the external wastegate for ease of tuning but you can do as you wish.
I built my own using a few parts from Quad when he had some leftover twins parts. Im using a he351 over a BHT3B and a 40 mm gate. The thing that different about my setup is i used a 3rd gen manifold upside down and not the typical 2nd gener. It is kinda cool to say that you built something but when it was all said and done I didnt save near as much money as i thought I would.
Also, with all the S300 top turbos being marketed with dual bigger volume wastegate volutes, is there any benefit to an external wastegate now (aside from more precise tuning I guess???)?
If you look at oldsmokey's pics you see the pipe coming from the bottom turbo to the front of the top turbo is made from using 2 90deg elbows. Mine is the same way. After I did this I found a place that sells "pipe donuts" which look alot better, go figure.
Here is the the site. Here is a link to the "donuts"
how reliable are twins? or should i say that kind of power when you get there? i want 600 horse and i want it to be reliable will it be or is that unrealistic?
What kind of boost are you guys making? and what needs to be done to the heads springs studs and do these heads need to be o ringed?
Old smokey what did your twins cost you?
Ah... makes sense now! Do you still have the silicone boot for the secondary turbo outlet pipe to the intercooler?
Also, it looks like you moved your windshield washer reservoir to behind the passenger side battery? Or is that the OEM location on newer trucks?
I liked the clean look of the v-bands and they won't blow off. However I can't find them now but someone makes silicone boots with v-band flanges attached to each end. They look really neat since they allow for flex but also won't blow off.
Caterpillar uses some steel v-band bellows on their twin turbo engines, but they're very pricey.
1985cucv
Dec 28, 2009 11:54 AM
kevellis32
Jul 16, 2009 06:57 PM
