anyone install there probe from the bottom?
Old Oct 13, 2005 | 07:16 PM
HorseHauler's Avatar
I called a place today to see if they install gauges, and they told me they did. he said they usually try to go in the manifold and drill it from the bottom on a lift. is he getting me confused with the fords or can this be done? I want mine done from the top of course between the 5th and 6th cylinder because its hottest (right??). He also said they usually follow the manufactuers instructions... does anyone know what Isspro states in there instructions on where to place the probe??
Thanks for the help,
Eric
Old Oct 13, 2005 | 07:39 PM
TAS05CTD610's Avatar
Gague
I have the Di-Procal, and I put the probe in the top behind cylinders 1,2, and 3. I know the back 3 run hotter, but to chance drilling the hold wrong, or tapping, I just went there. It was the best for me. As for drilling on the underside?? That sounds really odd. Maybe your right with ford and chevy with them being v-8's they go from under??
Old Oct 13, 2005 | 08:10 PM
yea it does sound odd. Im only going to let them touch my truck if they have already installed gauges in these newer dodges the right way... im not gonna let some knuckle head ruin my $48k truck
Old Oct 13, 2005 | 09:00 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Yeah if you put it in from the bottom your gauge will read upside down
Might be wise to talk with someone else or do it yourself
Old Oct 13, 2005 | 09:07 PM
PsRumors's Avatar
The Fords are drilled from the bottom at least on the 7.3s. I thought the Dodges got drilled at the exit of the manifold. Anyone know what the temp difference is between drilling between cylinders or at the exit?
Old Oct 13, 2005 | 11:11 PM
OOPS's Avatar
If you drill it at the exit it has to be to one side or the other. There is a rib in the middle, ask me how I know!!!!!
Old Oct 14, 2005 | 07:28 AM
signature600's Avatar
DUDE, bring it up this weekend, I'll help you put them in!! I did my buddies 04, and I need to pull my gauges and injectors.
PM me if you want, no sense in paying someone to do something you can get for nothing, right!!
Chris
Old Oct 14, 2005 | 07:36 AM
durasmack's Avatar
Chris
You are going to be in wilmington saturday night, right
Old Oct 14, 2005 | 07:49 AM
DMZ pull is Saturday???
Didn't know that!! I'll definately be there, I'll just have to work on Sunday!!
Chris
Old Oct 14, 2005 | 08:35 AM
nickleinonen's Avatar
hmm, have something to do with your user name???
1985cucv
14
Mar 24, 2009 10:19 PM
tomd
Dec 12, 2006 10:56 PM
Sea01Cummer
Sep 29, 2005 10:16 PM
TinJim
26
Sep 19, 2005 11:58 PM
