Anybody modified the H2 caps and used them..
Old May 3, 2005 | 02:33 PM
Dodgezilla's Avatar
Instead of machining them out to use the Dodge caps? The rims should fit no problem right? I'm probably getting a set of 5 really cheap and I was thinking about modifying the little Hummer part of the cap with some sort of Dodge or Cummins emblems or labels. Any ideas....
Old May 3, 2005 | 02:49 PM
RamWheelsBy4's Avatar
I dont think they are machined out so you can use the cap. The hole in the rim is too small to go on the axle. They need to be machined out to fit on the axle.
The center caps need to be modified to look right and fit. I have seen a post that someone trimmed about an inch off the Dodge cap to fit in a normal manner.
Old May 3, 2005 | 03:31 PM
cquestad's Avatar
Loot for Hoot's write up.
Old May 3, 2005 | 03:55 PM
HdPower's Avatar
I had the H-2 caps on mine for a while until I got tired of the look and modified the Dodge factory caps to fit. The fronts will fit...it's the rears that won't so what I did was use my hole saw that I used to cut the center bore of the wheel and used it to cut a hole in two of the H-2 caps, then I spray painted the axle shaft silver to match the caps.
Here's a link with h-2 caps on:
http://dodgetruckworld.tenmagazines....wer/153230.jpg
Here's a link with the Ram caps:
http://dodgetruckworld.tenmagazines....wer/156422.jpg
Old May 3, 2005 | 04:44 PM
4x4not's Avatar
Dodgezilla: Are these the ones listed in MD for $650? If they are, THEY ARE MINE
[edit]Just noticed you already have 315s, so are you talking about just wheels? I found some in MD complete[/edit]
Old May 3, 2005 | 06:53 PM
Dodgezilla's Avatar
These are in Alabama and it's a set of 5 rims w/ 315s for less $$$ than that. I really only need 3 tires though so I'm still thinking about if I want these or not. It's gonna cost a bit to get them shipped or to go pick them up. Actually, I don't even need these yet. I still have about 12-15,000 miles left on mine plus I just blew my mod money on the Quad box and I have a baby about to be born any day now........
If anyone needs 5 H2 rims w/ 315s cheap PM me and I will let you know how much and who has them. As I said they are in Alabama and the guy needs money quick.......
Jim Lane
Jun 28, 2014 11:27 AM
TrkEnvy
Aug 25, 2008 06:34 AM
jboIND
Apr 8, 2008 09:08 AM
Tree DR
23
Jan 23, 2008 03:51 PM
stock600
29
Dec 31, 2007 10:41 AM
