Another EDGE box question from a newbie
Old Jan 30, 2004 | 10:47 AM
Gunship Guy's Avatar
Question Another EDGE box question from a newbie
Have the 03 HO. Want to install the EDGE box and noticed on their website is says "gauges recommended."
My question is this...Do I need to go to the added expense of gauges if I'll only be hauling a 10,000 lbs camper? Can't imagine temps getting too high.
Thoughts please.
Old Jan 30, 2004 | 04:27 PM
Fummins's Avatar
Re: Another EDGE box question from a newbie
Thoughts please.
Absolutely! My opinion.
Old Jan 30, 2004 | 04:38 PM
Mopar_Mudder's Avatar
Yes
Old Jan 30, 2004 | 04:43 PM
Badunit's Avatar
When you install the Edge you will become your own warranty station. You really want to make sure you don't fry your engine. So, to save yourself money in the long run, get an EGT gauge and mount it pre-turbo.
Old Jan 30, 2004 | 05:16 PM
Scotty's Avatar
Top's Younger Twin
You's wants to play you's be prepared to pay...get the gauges as its better then running blind and guessing.
A scenario...you are climbing a grade and theres an intercooler hose leak, how would you know that without gauges? Probably would not at least for awhile.
With gauges you would see high EGT and low boost.
Play safe. Cheaper then that added expense of towing, down time and/or dealer issues.
Old Jan 30, 2004 | 06:19 PM
DPG's Avatar
DPG
Oh Yeah. If you can't afford the gauges, you can't afford to run the EZ. I'm running an EZ. I realize that my truck is second gen, but I can recall several times climbing the long grades with my fiver (about 11K pounds) and having to back off to lower the EGT. Talk to Haulin' In Dixie about what high temps can do.
Old Jan 30, 2004 | 10:44 PM
Thanks for the replies. Sounds like I'll need to get the gauges.
Which ones? Pyro, trans, anything else??
Are the instructions pretty straight-forward?
Thanks again.
Old Jan 31, 2004 | 01:23 PM
roadranger's Avatar
Do the 3rd gens have the lift pump issues of the 2nd gens?
A fuel pressure gauge is a MUST with the 2nd gens....
when lift pump dies, the injection pump is soon to follow.
Old Jan 31, 2004 | 08:10 PM
Scotty's Avatar
Top's Younger Twin
they are starting to fail now on several trucks and fuel pressures can be pulled down real low.
Havic801
Nov 16, 2011 02:34 PM
04ctd
Oct 5, 2006 08:27 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
Jehu
Sep 1, 2005 12:53 PM
coobie
25
Feb 23, 2005 04:05 PM
