Analog boost gauge install
Old Aug 12, 2007 | 10:47 AM
TNLoneWolf's Avatar
Hey guys I need some help. I've bought an Autometer 60# boost gauge and it comes with the tubing for connection into a ferrel fitting at the gauge and a "t" fitting on the engine. My 2005 2500 doesn't have any vacuum lines that I can see. My truck has the CFM+ intake elbow with a location for a boost gauge all ready to drill out and use. Now with all that being said, the question is, what size connector and type connector do I get? I know very little about "pipe thread" fitting names and sizes. Thanks for any help provided.
Old Aug 12, 2007 | 10:55 AM
jrussell's Avatar
Autometer usually uses 1/8" NPT (pipe thread) fittings. It should say in the intructions.
Instead of drilling and tapping your manifold you can get a "boost bolt" from Geno's or Diesel Manor. That will replace an intake manifold bolt and give you an 1/8" NPT port on top for your gauge. Doing it this way is much easier than removing, drilling, tapping, and reinstalling the intake horn. I've also read that the intake manifold is a much better place to monitor boost than the intake horn.
Old Aug 12, 2007 | 11:06 AM
Pooter's Avatar
Thats what I did, the boost bolt works great...
Old Aug 12, 2007 | 11:10 AM
Mega07's Avatar
Yep x3, boost bolt is quick and easy. Just did my guages yesterday!
Old Aug 12, 2007 | 11:23 AM
TNLoneWolf's Avatar
Well, it sounds like the boost bolt is the way to go. Thanks everone.
Old Aug 12, 2007 | 01:04 PM
quadman20's Avatar
I learned the putting a couple zip ties on hose at fitting. Man first time I hit throttle hit 34 psi then nothing. Dang hose blow off at the intake talk about a whistle.
Old Aug 12, 2007 | 03:11 PM
TNLoneWolf's Avatar
Thanks Quadman, that's good advice.....
dodgerdog
Dec 10, 2008 10:15 AM
kanuckle head
14
Oct 22, 2008 10:56 AM
CLeger67
Jan 10, 2008 08:05 PM
RamWheelsBy4
39
Sep 4, 2006 10:59 AM
Bradleysram
Apr 28, 2005 12:22 AM
