Analog Rail Pressure Gauge
Old Aug 29, 2006 | 09:24 PM
RamWheelsBy4's Avatar
Smile Analog Rail Pressure Gauge
My new analog DiProcol Rail Pressure Gauge arrived yesterday. Will install on Saturday. I am excited, maybe this will help tune in the many stacks I have been trying lately. Most will drain the rail, or at least I think they do. Now maybe I can find out for sure. It is a nice kit.
Old Aug 29, 2006 | 09:50 PM
4x4not's Avatar
Sweet. Is this the kit that doug was working on? Where did you get it, and how much? Inquiring minds need to know!!
Also, I sure wish DiPricol would make an ELECTRICAL version of their standard 30psi fuel pressure gauge, so I could get both to match and mount them on a dual-steering column mount.
Old Aug 29, 2006 | 09:54 PM
Yes it is the Kit Doug was working on. I found info here http://www.dieselspecialtiesllc.com
Old Aug 29, 2006 | 10:44 PM
acook's Avatar
could you pm me the price, i dont want to email the place if i dont have the money...
Old Aug 30, 2006 | 12:38 AM
qzilla's Avatar
That is Doug's kit. Looks nice.
You should also note that for not a lot of money you can add the Rail pressure to your Commander. Just a thought.
You will also be able to add the low side of the fuel pressure at the same time.
Quad
Old Aug 30, 2006 | 04:33 AM
dogger's Avatar
Rail pressure sensor
Quad
Quad which vendors handle the rail pressure sensor? The only fuel pressure sensor I have seen listed is for the lift pump. Thanks.
L8r,................dogger
Old Aug 30, 2006 | 04:58 AM
doug60's Avatar
Got mine also, please post wireing tap points after you install, colors & location. thanks
Old Aug 30, 2006 | 06:10 AM
wap's Avatar
wap
Keep us posted on the intall, if it aint brain surgery I gotta have one.
Old Aug 30, 2006 | 07:26 AM
MikeyB's Avatar
Doug did good!
MikeyB
Old Aug 30, 2006 | 08:07 AM
4x4not's Avatar
Dogger: The FP Kit for the Commander includes a wire in the harness to tap into the rail pressure sender. It will read the rail pressure along with the LP pressure.
Old Aug 30, 2006 | 09:12 AM
Luken's Avatar
I thought this thread was about Doug's kit.... Not a sales pitch for quad
Old Aug 30, 2006 | 09:46 AM
WUnderwood's Avatar
that is a quality looking kit! are there any other ways to monitor the rail pressure, other than the gauge, or the Quad chip?
let us know what you find
Old Aug 30, 2006 | 11:47 AM
Timinva's Avatar
DTR Advertiser
Got mine today. The wiring kit and gauge are top notch. Tim
Old Aug 30, 2006 | 11:49 AM
cquestad's Avatar
I second that....Doug's kit rocks. Now I need to start replacing some of my older Diprocal's with the Optix.
Old Aug 30, 2006 | 04:51 PM
abc4yew's Avatar
Hmmmm, where to put gauge number 7....only need it for tuning.......maybe a single steering wheel pod or maybe a double cause I'm sure someone will come up with another gauge I absolutely need.... good work Doug...I wish someone would come up with a 40k sensor for us crazies.....HaHaHa. ks
