AltecRunning Board LEDS installed!
Old Jul 3, 2006 | 11:23 PM
pet05's Avatar
Cool AltecRunning Board LEDS installed!
Take a peak into my GALLERY and check-out the new Altec LEDS. I installed them with 3M double-sided grey tape. They are wired to the fog lights.
I like them but some might not. They serve these 3 purposes for me:
1 - They provide additional safety by illuminating the side of the truck at night.
2- They light-up the step bars so one can see where the bars are in the dark.
3 - They look cool to me
Let me know what you guys think....
Old Jul 4, 2006 | 12:16 AM
TAS05CTD610's Avatar
I didn't see anything in the gallery?? Maybe I'm missing something
Old Jul 4, 2006 | 12:23 AM
pet05's Avatar
Sorry...Still waiting for the web master to approve the photos...Maybe he's out of town for the 4th??
Old Jul 4, 2006 | 01:26 PM
pet05's Avatar
The PICS are up!!!
Old Jul 4, 2006 | 01:39 PM
Rauschbo's Avatar
- pretty sharp!
Got some installation play-by-play and part numbers / location to get the components from?
Old Jul 4, 2006 | 03:12 PM
socal 610's Avatar
Old Jul 4, 2006 | 05:16 PM
pet05's Avatar
THANKS SoCal!
THANKS SoCal!
They are the Altec Amber LED Screamer Lites. www.AltecProducts.com
They are 57" long and were very easy to install. I bought mine from Summit Racing.
They come with tabs that you are supposed to drill and screw into the sheetmetal on the bottom of the car. I did NOT as I don't like drilling into a new truck.
I opted for the 3M Grey/Red tape. This is the STRONGEST 3M double-sided tape.
1 - Measure the distance from the front of the cab to the rear of the cab. Mark where the center is. I installed the lights so that they were centered and have then same distance from the front of the cab (about 11") and the rear of the cab.
2 - I cleaned the area very well with rubbing alcohol and then cleaned the LED lights.
3 - I installed the 3M tape to the back of the LED light bar.
4 - I then installed the LED lights VERY CAREFULLY and SLOWLY on the bottom curved area below the truck.
5 - I pressed the LED bar so that the tape sticks properly to the body. I used a firm constant pressure.
6 - I ran the wire loom thru the fenderwell area and then spliced the wires into the fog light wiring assembly.
The lights turn on with the fog lights. They are not going anywhere. The 3M tape is stronger than the double-sided tape they use to hold the Dodge and Cummins emblems.
Old Jul 4, 2006 | 08:07 PM
MikeyB's Avatar
Looks good to me!
MikeyB
Old Jul 4, 2006 | 09:12 PM
boostjunkie1's Avatar
I really like them, but I would have wired them into the parking lamps! That way you wouldn't have to run the fogs to have them come on!! Just my OPINION but hey they look great! How much did they run ya??
Old Jul 4, 2006 | 09:29 PM
pet05's Avatar
It was easier for me to tap into the fog lamps. I was looking to do the parking lights but the wiring was harder to access.
They were $160.00 DELIVERED for the set.
Old Jul 9, 2006 | 08:48 PM
RAMFREAK26's Avatar
Reconaccessories.com has them. Recons function as a running light as well as a turn signal, and are longer and less expensive.
Old Jul 9, 2006 | 09:29 PM
phloop's Avatar
Could have ran a wire back to the rear where the 4 pin trailer plug is hidden under the bed. That is where I ran my wires for the extra lights I installed.
Dodge Demon
Apr 29, 2007 12:38 AM
willysrule
May 7, 2006 02:50 PM
loch
Feb 5, 2006 07:48 PM
moparguy
Apr 13, 2005 12:03 AM
