Transmission gauge question
Old Jul 9, 2006 | 09:10 PM
howe719's Avatar
alright i got gauges. i got the turbo boost and the tran temp. only probably is i have a 6 speed and there is not place to screw in the transmission temp brushing on a 6 speed only on a auto. I have all the other gauges i need in my outlook screen that came with bully dog so i really dont need to buy any other gauges so i want to try to make the transmission gauge work if i can. any ideas. can this be DONE thanks
Old Jul 9, 2006 | 09:58 PM
TonyB's Avatar
Sure there is...use the fill or drain plug...The gauge should have come with a bushing. if not, take the drain plug (drain plug is preferred as it is always immersed in hot oil) & match it up. It's possible the plug is metric. In this case, your best bet is http://www.mcmaster.com/ and search for metric pipe fittings. You'll need to know what size, though. mcmaster also has a great reference online & should be able to give you ID/OD sizing, if you have calipers to measure the threads.
HTH
Tony
Dauntless
15
Aug 30, 2016 08:37 PM
montemorris
Mar 16, 2005 12:53 PM
MPowell800
Aug 19, 2004 01:16 AM
Pickle
Apr 17, 2004 01:17 PM
Pickle
Feb 10, 2004 09:19 AM
