which air intake?
Old Feb 17, 2009 | 12:14 PM
claydawgs85's Avatar
which air intake?
I am thinking of puting a air intake system on my truck and i dont which system would be the best for me. I ahd norrowed it down two intakes the new K&N system and the banks system. If you guys coudl give me some advice that would be great. thanks
Old Feb 18, 2009 | 08:25 AM
michigan mark's Avatar
Make your own, its all a gimmik! I put 4 inch hole in bottom of stock box, drop in kn filter yes kn. Just dont over oil!! Over oiled right out of box.
Old Feb 18, 2009 | 08:38 AM
055055.9's Avatar
Agreed! Well except for the K&N
Old Feb 18, 2009 | 08:43 AM
sdmark's Avatar
If you are talking about the air filter box, then I agree. Save the money and make your own. Get a drop in filter and remove the turbo silencer. If you are talking about the intake on the other side of the charge air cooler than I recommend the ATS or the CFM+. Either way this mod won't get you much without doing others as well. IMHO You are better off starting with a tuner.
Old Feb 18, 2009 | 08:52 AM
Yes box, can use any filter of choice.Intake on motor just port it out yourself you can get the stocker to flow pretty good!
Old Feb 18, 2009 | 12:04 PM
jasonstacked06's Avatar
I made a ****** whistler off this site I love it it was alot cheaper then buying and it sings like crazy. good luck which ever way you do it
Old Feb 18, 2009 | 12:48 PM
JJPage's Avatar
If you do not want to modify your stock setup, and be able to return it to stock later, then I suggest an AFE MegaCannon.
It comes with a new intake tube and air box, you also get a pro-guard 7 AFE re-usable filter, with all the neccesary clamps and hardware. I looked at one that was installed on a new 6.7 at the Dishman Dodge lot, very nice!
(you can substitute a Cool Blue Hose in place of the intake tube)
It is far better than either of your two choices of K&N or Banks.
Jess
Old Feb 18, 2009 | 04:21 PM
Bswope's Avatar
I love my S&B, for the money.... its a GREAT UNIT!!
Old Feb 18, 2009 | 06:20 PM
joe189man's Avatar
i agree the S and B is a good buy and the turbo sings at around 1200 rpm
MTC's Avatar
MTC
Like said above...Cut a 4" hole in the bottom of the stock box, add about 2' of drain pipe to the bottom, gut the intake tube and remove the silencer ring. Costs maybe $10 and works just as good as a $400 intake. Oh yeah, and add a free flowing drop in filter.
Taquache
21
Jun 24, 2012 03:11 PM
herb
Jul 18, 2008 08:25 AM
Dodgewincity
13
Jan 19, 2008 05:41 AM
D45
17
Dec 6, 2007 01:52 PM
BA05'CTD
Jan 7, 2007 03:08 PM
