Air dog
Old Nov 26, 2015 | 11:57 AM
918dodge's Avatar
Air dog
I'm new at the whole diesel truck game. I have a couple questions about them. I have a 06 dodge 2500 with a 5.9 and I'm looking to buy air dog off someone that bought one and didn't need it because it was his ecm.it was for a 03 would it work ?
Old Nov 26, 2015 | 01:25 PM
ftltmp's Avatar
I can't say for air dog, I have the fass and as far as the pump it should work but you will need to drop the tank on your truck to remove the factory pump. I think you will have in install a draw staw on the 06. The 03 the pump was on the factory filter housing. Someone who has an air dog may can give you some better info.
Old Nov 26, 2015 | 01:30 PM
918dodge's Avatar
Thanks this is my first diesel truck and I'm learning as I go
Old Nov 26, 2015 | 08:26 PM
ftltmp's Avatar
Not sure what pump you have maybe this will help...
http://www.pureflowairdog.com/manuals/A4SPBD002.pdf
Old Nov 26, 2015 | 08:32 PM
918dodge's Avatar
Thanks I need some ppl to tell me things to look for with my truck because it's my first truck any advice helps
Old Nov 30, 2015 | 08:19 AM
soulezoo's Avatar
DTR 1st Sergeant
If your in tank pump is working fine, leave it alone for now.
The airdog has reliability issues. They used to be sold in the online store here. They stopped due to too many warranty claims from failing units.
Old Nov 30, 2015 | 09:46 AM
918dodge's Avatar
Really thanks
Old Dec 1, 2015 | 08:55 PM
mykaos's Avatar
Your 06 has a pretty stout in tank pump. I would recommend additional filtering. There are a couple of options at substantially less cost than a aftermarket lift pump.
Old Dec 1, 2015 | 08:59 PM
918dodge's Avatar
What would search for ?i was told The truck has 90 hp injectors and don't want to mess anything up
Old Dec 1, 2015 | 10:03 PM
mykaos's Avatar
dieselfuelfilterkits.com for starters
Old Jan 10, 2016 | 11:33 AM
Equalizer 2's Avatar
About 8 months ago I replaced my AirDog with a FASS as the dog died. Had it about 8 years or so. The FASS was easier to mount the system than the older AirDog but that may or may not be the case now. After seeing that the AirDogs had problems wish I had stayed a bit more active and current on here.
duster75
Sep 9, 2009 11:02 PM
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
BIGHEAD
Jul 24, 2006 07:49 PM
NWDave
Mar 13, 2003 05:58 PM
