Aftermarket thermostat housing?
Old May 15, 2008 | 11:16 AM
Dan Marino's Avatar
anyone know of a source for a thermostat housing that is straight up vertical or a different shape than the stock housing? I was told by ATS that they couldnt give the name of their supplier for the housing(stupid) but he did say that cummins made one for their industrial application motors. So I called cummins and they acted like they had no clue what I was talking about.
Old May 15, 2008 | 11:25 AM
53 willys's Avatar
they probably wanted a engine number right!!
I dont know witch ones have the straight hosing..but I can check all our 12v's at work and see if they do...if they do I will write down the number and post it for you...but I dont go to work till Friday..good luck
Old May 15, 2008 | 11:32 AM
Dan Marino's Avatar
53 they wanted numbers for the industrial motors - I was like I am not asking about that motor...Im asking about a thermostat housing...He said I have no clue what you ae talking about. WOW
Old May 15, 2008 | 11:37 AM
53 willys's Avatar
there are MANY MANY MANY MANY MANY versions of the cummins engine and the ONLY way for the guys at cummins to look something up is by the engine serial number..it would be dang near impossible for a guy to memorize all the configurations or part numbers..so I can understand why they could not help you...we have quiet a few different industrial 12v, 24v and CR configurations..I will see if any have the housing you need.
Old May 16, 2008 | 05:10 PM
53 willys's Avatar
Engine#56809149
this is from a 01 24v CTD from a F750...
Bookshelf
May 30, 2009 01:17 AM
funcruise
Jan 1, 2009 10:37 AM
swany
Jun 25, 2008 06:53 AM
TxDiesel007
Feb 18, 2007 01:29 PM
Redleg
Mar 3, 2003 04:29 PM
