Advice needed, More air???
Old Mar 6, 2008 | 07:08 PM
DZLROKET's Avatar
I need some help here and it seems like there is some expertise here. To be brief, I put a smarty JR on my ride and now after a few hard excel. runs the filter minder is way intoo the yellow. I reset it and did ONE run and it is back in the yellow again. I am running a stock airbox with an Amsoil filter. Seems like I need more air! any suggestions?
Old Mar 6, 2008 | 07:10 PM
mulisha's Avatar
yeh. get rid of that air robbing garbage stocker, and get a AFE stage2 .
Old Mar 6, 2008 | 07:16 PM
MegaMagoo3500's Avatar
X2!!!!!!!!!!
Old Mar 6, 2008 | 07:25 PM
coreydr2003's Avatar
Paper filters are really bad for building power, ya AFE
Old Mar 6, 2008 | 07:29 PM
Dynocon's Avatar
My stock truck with a new filter would suck the filter minder down.
Cheap option #1. Swiss cheese the air box,
Cheap option #2. Get 2.5' of 4" non perforated corrigated drain pipe and a 3"x4" PVC adapter. Cut a hole in the bottom of the air box and inset the adapter. Attach the 4" pipe to it and run down between the frame and inner fender(straight down) trim to fit after secured. I dropped a conical critter guard in the top just in case I caught a Ford or Chevy.
Option #2 give you a cold air intake which test have shown HP drop with an increase in intake air temperature.
Old Mar 6, 2008 | 08:02 PM
firemanram's Avatar
X2 ! Nobody makes option #2 (cold air intake), do they? I think you can find a aftermarket air intake.
Old Mar 7, 2008 | 03:29 AM
Festus's Avatar
If they did, it would be far more expensive than the <$30 it cost me from Home Depot for the parts to do it myself.
Old Mar 7, 2008 | 05:24 AM
Hounddog's Avatar
Does this help any? www.psmdiesel.com click on products.Let us know if this is what you had in mind.
Old Mar 7, 2008 | 10:21 AM
Big Horn 06's Avatar
Here's my Home Depot Special, and it cost me only $11 Toilet flange, some flex drain pipe, and some nuts n bolts. 30 minutes worth of labor. I've never pulled the filter minder down since I put in the Amsoil air filter.
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
herb
Jul 18, 2008 08:25 AM
bigragu
Apr 29, 2008 07:52 AM
BIGHEAD
Jul 24, 2006 07:49 PM
thumper
Dec 30, 2004 07:10 PM
