Adjustable Turbo Boost Elbow
Old Mar 12, 2009 | 09:49 PM
jgiachino's Avatar
Where can i get an adjustable boost elbow to use with my HTT Turbo?
Not sure if they're available for my setup...but I just want something i can adjust the boost level easily???
Thoughts?
Old Mar 12, 2009 | 09:52 PM
homewrecker's Avatar
e-bay....................they are cheap.I used one on my first HTT.The wastegate rod is a pain in the rear to adjust with the turbo on the truck.
Old Mar 12, 2009 | 10:21 PM
jgiachino's Avatar
Any of the $19.95 ones? Does any dodge one work with the HTT?
Old Mar 12, 2009 | 10:26 PM
yes....they will work.
Old Mar 12, 2009 | 10:32 PM
I just looked on e-bay.That price is high.There used to be some for $10.I just did a quick search and saw them for $15 from Source Automotive.Might do a little more digging and come up with something cheaper.
Old Mar 13, 2009 | 12:08 AM
jgiachino's Avatar
I'll order one from Source Automotive tomorrow...i can swing the $15....cheapest mod yet!
Thanks for the quick help / followup!
Old Mar 13, 2009 | 01:00 AM
Swarthy Dago's Avatar
elbo
will this work ? you can make one, go to https://www.dieseltruckresource.com/...=230363&page=5
and see my post at bottom of pg.
Old Mar 13, 2009 | 09:58 AM
soulezoo's Avatar
DTR 1st Sergeant
I made my own last night... the only cost was $.18 for the set screw. It took about 5 minutes total.
Old Mar 13, 2009 | 10:43 AM
cquestad's Avatar
Terry...
What did you use? A brass valve with 1/8" barbs?
Old Mar 13, 2009 | 01:00 PM
soulezoo's Avatar
DTR 1st Sergeant
Well, not a valve, but yeah, a standard brass elbow with the barbs. I had to trim back on the barbs a little to be able to screw in. I did this also to the stock elbow used on the HE341.
But basically, using a #7 drill bit and a 1/4 coarse thread tap and long enough set screw to completely close off air passage if necessary. Using my aircompressor's regulator set to desired psi, I screw the elbow into the blow gun for the compressor, hook up the wastegate line and dial in the setscrew until the wastegate stops operating, back it off just enough that it starts to open and voila! I use thread lock to ensure it doesn't move.
Old Mar 13, 2009 | 03:18 PM
AH64ID's Avatar
Don't forget the bleed hole you have to drill.
Hdog
Oct 27, 2014 10:52 AM
jnovak
Mar 20, 2011 09:39 PM
dodgediesel
14
Dec 14, 2006 09:54 AM
chuxtruk
May 12, 2006 01:59 PM
turbo dreams
Jun 1, 2005 02:49 PM
