6 inch lift questions
Old May 24, 2009 | 06:46 PM
Nsomniac05's Avatar
Good afternoon DTR,
I started installing my lift this morning, and i am almost done. It is a 6 inch pro comp coil spring kit. I cannot figure out how to get the pitman arm off. I have tried multiple pullers and pickle forks. is there something special I need? if so where can i get it? also, once your ready to reinstall the shocks, How do you compress them down enough to bolt down the towers? It may seem simple, but I have 2.0 Inch reservoir shocks and the truck is way up in the air.
thanks
Old May 24, 2009 | 07:36 PM
megacabdad's Avatar
Try a pitman arm puller...http://www.sjdiscounttools.com/kd2289.html
Bench press, floor jack, bottle jack, what ever it take to compress the shock to fit.
Old May 25, 2009 | 08:55 AM
XLR8R's Avatar
I just bolt the shock tops to the towers and push them onto all 3 studs... and thread nuts. Ladders are your friend on lifted 4WDs.
Old May 25, 2009 | 01:28 PM
Nsomniac05's Avatar
I tried a puller that looked like this and the hole wasnt wide enough. so I tried some universal pullers and they werent tough enough.
and your talking about sitting something on top of the shock thats heavy enough to compress it right? The passenger side is the problem because i cant put the shock tower on until I compress the shock lower than the turbo.
Old May 25, 2009 | 01:56 PM
Ace's Avatar
Ace
I wouldn't beat on the pitman too hard with a fork unless you are prepared to fix the leaking sector shaft seal that occurs after a bit much of that type activity. If heat and a puller don't work you might as well just cut it off. sometimes those things will be frozen on there beyond all hope of normal removal.
Old May 25, 2009 | 04:59 PM
Mocho's Avatar
Get the puller to about 200 ft lbs then hit the side of the pitman arm a few hits and it will be off. Will come off a lot easier then a puller at over 400
Old May 25, 2009 | 06:58 PM
megacabdad's Avatar
My simple mind needs pictures...
Is this what you are looking at?
http://www.4wheeloffroad.com/techart.../photo_12.html
Old May 25, 2009 | 08:35 PM
beaver76's Avatar
I bought and installed the same lift kit. I actually used a tie rod end puller. I just pue some pressure on the pitman arm beat on each side of it. Then put a little more pressure then beat again. I repeated this until it popped off. It took about three minutes and worked perfect. Didn't bend or break the teeth on the cheapy puller.
Old May 26, 2009 | 06:16 PM
TrkEnvy's Avatar
The pitman arm is the drop arm that is attached to your steering box..
http://www.pavementsucks.com/tech/steeringupgrade.php
sixth pic down is the best view of it..
Old May 26, 2009 | 06:27 PM
megacabdad's Avatar
I was trying to understand why the turbo was getting in the way of the shock tower...
Thanks, tho.
Old May 26, 2009 | 06:37 PM
TrkEnvy's Avatar
my mistake.. and no problem..
Old May 27, 2009 | 11:16 AM
mattyfz450's Avatar
had to cut mine off
Old May 27, 2009 | 09:56 PM
Nsomniac05's Avatar
thanks fellas. My buddy let me grind down his puller it originally didnt work cause it was too small. I never would have thought to hit the screw once you tighten down the puller. It popped right off. Now I got to center my axle and get in the track bar bushing its also a pain in my forward point of reference. when I get that and my steering geometry where it needs to be. Ill be good.
hwebb
Mar 1, 2010 12:42 PM
KKoteles
30
Apr 16, 2008 11:07 PM
KKoteles
Jun 19, 2007 06:06 PM
shaft
Sep 1, 2003 03:37 PM
bdaniel
May 6, 2003 04:43 PM
