56 gallon fuel tank
#32
Originally posted by Forrest Nearing
if it's a tool box/tank combo, I don't want it... the 90 gal combo setups yield a toolbox slightly larger than my glove compartment. I like the L-shaped tanks. the only take up another 5" or so of bed over a box.
Forrest
Forrest
I have the combo, and the tool box is definitely not that deep, but it is certainly as big as 20 gloveboxes...I have 3 wetsuits, 3 life jackets, jetski booties and gloves, a gallon of oil, and the lift kit to launch with in there... as well as a tow strap for emergencies etc. Far from a worthless amount of storage in my view. No, it's not as big as an entire truck toolbox but its extra space IMO.
#33
Originally posted by Lightman
Forrest, if you are getting 90 gals of capacity, isn't it only a plus to have ANY extra tool or storage space? Why get a L tank that takes up MORE bed space, and doesn't have any storage?
my current toolbox is just on the small side. I couldn't deal with any smaller. I can deal with giving up a little room in the bed for all that fuel capacity!
#34
Most of the "replacement tanks" I've looked at hang down 2 to 4 inches farther than the stock tank. On that note do you have to modify the fuel pickup assy to reach the bottom of the sump?
#35
Originally posted by Mopar_Mudder
Does the replacement tank loose you any ground clearance?
In bed tank is out of the question for me, I bought a long bed for a reason......
#36
I already have a toolbox that I'm happy with... the L-shaped tanks are designed to be used in conjunction w/ an across the bed box like mine. in fact, depending on the height of the lower portion of the tank, I may be able to mod my box to give it some more depth.
#37
All the fuel tanks I read about that replace the stock tanks hang down lower than the stock ones. I had read they ONLY recommend the replacements on 4X4 trucks that have the higher ground clearance.
Frank
Las Vegas, NV.
Frank
Las Vegas, NV.
#39
Top's Younger Twin
I have a 68 gallon tank in the bed and the 34 [?] on the truck.
Running loaded with strongman gear I can go without fuel from here to Denver...but I usually stop in Cheyenne and fuel up at the Flying J. My range varies with the load and terrain. I get 13.5 to 15 with the usual load.
11 with a big load. I can handle that as I am still going with the traffic and very VERY few hills will pull me out of 6th.
Ed, your taking a whoopin' on here.
SWEET!
SWEET!
#40
Originally posted by Stingerpup
According to the web site, it drops below the frame by 3". I looked at that today, and that is just out of the question.....too low.
trailduster440
11-23-2012 12:35 PM
The_Head
04-29-2010 10:54 PM
rockcrawler304
60
05-30-2008 05:40 PM
Great_big_juan
10-01-2007 01:01 PM
ddestruel
01-06-2007 10:12 PM
