550HP goal----> how?
Old Jul 14, 2007 | 04:44 PM
hllbllyhellion's Avatar
I have never driven one of these trucks with an After Market turbo. Just curious if he was talking about spool up time (I didn't think that turbo was quite that big either), or maybe something else? thanks for the reply.
Old Jul 14, 2007 | 05:17 PM
Luvnacumns's Avatar
Originally Posted by jwb600
he means the turbo is too big to tow with. not trying to answer your questions for you shane. it has so much lag it is not meant to tow with. its more for competition really. drag racing & sled pulling. its around 71mm. its not small at all. it takes a couple seconds to spool with 250hp worth of fueling on an automatic truck. does that make any more sense now. I drive it everyday but it can be a pain in the rear. its meant to get out and go. on the interstate it does great. in town the boost gauge barely moves
Answer away my friend!!! You know how it is to drive tooo!! He is correct it takes 12 pounds of boose to get that beast to light but once it does you'd better be ready!!! Which is right at 1900 rpm's.. With a turbo that large it the tranny has to keep the torque converter locked to keep the rpm's up that high.. If I kept it in o/d lockout it was awesome but anything else was a lot of strain on the tranny and motor to keep it there and if it got bogged down it took a lot to get it back up there.. Not that I dis like the turbo if I was pulling or racing OMG!!! It is insane!!!
The bottom turbo on my twins is an 80mm!!!
Old Jul 14, 2007 | 06:37 PM
53 willys's Avatar
are you auto trans??
Old Jul 14, 2007 | 07:35 PM
Luvnacumns's Avatar
Mark, yes Jesse is running a built auto
Old Jul 14, 2007 | 11:33 PM
morkable's Avatar
Shane what twins did you get? Is that the IIS with the Big Brother?
Kevin
Old Jul 15, 2007 | 02:01 AM
Luvnacumns's Avatar
Kevin
Kevin, I got Nathan Wright's Kit.. He is only 1-1/2 hours away and I figure If I need help that's as good as it gets!! One heck of a nice guy! His instructions aren't too hot but he told me he is working on that and should have them done this week but he did give me some really good pic's of an installed set so pic's are always good for me!!! It uses the stocker on top and a 80 MM B4 on bottom... He said it should be a bit better than the 5k along but towing will be a dream!!! So hurrry up and get here Friday because all teardown begins!!!! I hate making a living with my truck!!!
Old Jul 15, 2007 | 02:02 AM
Luvnacumns's Avatar
Plus I've allready found a 6240 to replace the stocker so it won't be onthere long!!! He will just have to make a new hot pipe!!!
Old Jul 16, 2007 | 01:53 PM
DreamSRT6's Avatar
i'm guessing that the lag on the silverbullet is not that big or am i way off? reading the previous posts says that towing gonna be an issue with certain setups (obviously BIG turbos) and would that be the same with this one? is the twin turbo setup good just for top end power or does it help the bottom too? not too familiar on them and learning tons as i go. also, if i need 550 just once in a while, would propane or nitrous be a better choice then such a big turbo?
thanks once again.
Old Jul 16, 2007 | 02:36 PM
BothellDiesel's Avatar
I hit 548 with listed mods. No stacking, No drugs, No extreme tuning
06dodgedrw
13
May 21, 2009 09:00 AM
RedRam410
52
Jun 4, 2008 06:34 PM
diggity dodge
18
May 19, 2008 08:59 PM
SlowSixSpeed
Apr 6, 2008 10:39 PM
1Coyote
25
Jul 9, 2006 04:40 AM
