48RE OD problem !?
Old Aug 23, 2008 | 12:25 PM
  #31
no_6_oh_no's Avatar
Originally Posted by #2 only
All the t/h button does when you press it once(tow/haul mode) is lock up the converter sooner, so your o/d doesn't slip or hunt as much.
My tow/od button functions properly.
Not really, the TH mode advances the governor pressure faster in relation to the APPS position so you get more positive and later shifts along with 2nd gera lockup. The advanced gov pressure gives the lockup a better and faster apply. The gov pressure solenoid and transducer not working correctly will cause many problems in cluding the shuttle shift and intermittent OD. Just depends on when it is failing to respond to the ECU signals.
Old Aug 23, 2008 | 04:17 PM
  #32
#2 only's Avatar
My o/d has a brain of it's own,it goes in and out when it wants to,maybe b/c of a defective gov pressure solenoid.
Old Sep 9, 2008 | 06:19 PM
  #33
#2 only's Avatar
has anyone fixed the o/d problem by replacing the gov pressure solenoid & switch?
Aloha
Aug 6, 2005 11:52 AM
AK RAM
Jan 27, 2005 04:26 PM
propinc
Nov 14, 2004 10:51 AM
Cold Diesel
Aug 10, 2004 08:01 PM
DockHigh
26
Sep 9, 2003 08:48 AM
