2006 Ram 3500 RV Build
So, I want to remove the bed and build an RV coach in the back. It will be aluminum and fiberglass. I have a few questions about modifying the truck before I get to building the coach. (The picture shows a rough concept.)
I don't know just how much the coach will weigh when I'm done, but it should be well under 1 ton. But because I want it to be for off road use (nothing extreme, just boon-docking), I want to beef up the suspension using an adjustable Air Ride suspension, increase the tire size (currently using stock wheels), and add a snorkel plus run the exhaust up the side of the coach in a recess up to the top. I'm not opposed to running a straight 3" exhaust but need more info on that. Basically, I'd like to copy some of the high end RV features (see https://earthroamer.com) plus add a few of my own, already mentioned, but do it on a shoestring budget.
Any thoughts on the performance side of things (or anything, really)? Thanks.
It's a dually, 4x4, SLT, Turbo. "Shoestring" is relative.
God bless.
IMHO, do it with a dually and then add some stuff to it:
Manual locking hubs
It'll be a little expensive, but it'll cut down on wear and tear in the front end and save some fuel mileage.
Swap the 4.10's for 3.73's
Again, its a fuel mileage thing, and since you're not hauling over 10k pounds it's a good idea.
Titan fuel tank
So this one is a bit spendy but having about 52 gallons of fuel in the OEM location is a win.
Onboard air
Having an air bag system, skip the kit and just bag it. Then turn around and get at least a 5 gallon tank and an EDC (engine driven compressor). If you want to know more about that you can look here.
-Kris
Manual locking hubs
Titan fuel tank
Onboard air
-Kris
Thanks for all of that. I do appreciate it.
I'd really love to have a bigger fuel tank (Titan 60?). The only concern about that is ROOM. I've got to fit a fresh water tank, a grey water tank, a black water tank, a generator...this will be one of my early challenges. Hopefully, if I can reroute the exhaust up the side, it will make more room for some of these. BTW, should I toss the muffler?
I probably won't do the locking hubs, just because everything's already there. Same with the gearing ratio, too many other expenses right now. But thanks for the input.
I definitely am looking into air bags. Maybe torsion bars too, if they'll fit. And what about beefier springs?
Onboard compressor? Sure! Will it fit? Maybe, if I can get a custom front bumper/grill guard with a winch (or stick it someplace else). (?)
IDK, I may have to raise the coach floor a bit more than I'd like, just to fit everything in there. Not my first choice. Not at all.
Cheers.
Cheers.
jfisher04
15
01-31-2007 08:32 AM
65pacecar
10-01-2006 04:50 PM
N5IBM
06-03-2006 12:00 PM
pet05
06-01-2006 12:50 PM
DanTana
03-06-2006 05:56 AM
