2006 ram 3500 5.9L Turbo Diesel engine turns 2 revolutions after key is switched off
Old Jan 25, 2007 | 01:06 PM
jfisher04's Avatar
Hey everyone! I am hopeing that someone out there has heard of this problem before because noon else has. I have a 2006 ram 3500 5.9L Turbo Diesel engine and it turns 2 revolutions after key is switched off. It is NOT the chirping issue that some have. It literally runs a couple seconds AFTER the key is out of the truck and it has been turned to the off position. Before anyone asks, it doesnt matter if I towed anything, let in run a while after driving to cool off, or whatever it does it EVERY single time no matter what. I have had it in the dealership a couple of times and they flashed the computer, reset the computer, changes solenoids, checked relays and fuses and they say that nothing is wrong. This is the 6 speed version. Please let me know anything that will be helpful. Thank you!
Jeremy
Old Jan 25, 2007 | 02:39 PM
ptgarcia's Avatar
Leaky injector(s)?
Old Jan 25, 2007 | 02:53 PM
jfisher04's Avatar
Nope, I already thought of that, no fuel in oil and no fuel on backside.....unfortunately.......just got off the phone with Cummins and they said hell no its not suppose to do that.....like I didnt know that....grrrrr
Old Jan 25, 2007 | 03:44 PM
Luke S's Avatar
Every 07' that I have on the lot does that. 5.9 and 6.7 both do it. Never gave it much mind.
Old Jan 26, 2007 | 12:59 PM
CoastalDav's Avatar
Its my opinion, you should visit your local Cummins Authorized Shop and pose the question. Apparently the Dealership is weak on ideas.
Dave
Old Jan 27, 2007 | 09:47 PM
Jim Dynomite's Avatar
Do you push the clutch in when you shut down?
Maybe your confusing the tranny rattle with engine revolutions.
......................Jim
BTW you need to post this in the 2003-07 forum.
Old Jan 27, 2007 | 11:04 PM
Got Juice?'s Avatar
Jeremy
Perfectly normal. Mine does the 'wet dog shake' that all CTD's have on shutdown.
It's part of the Cummins character.
Old Jan 27, 2007 | 11:20 PM
bigredBCS's Avatar
he said in his first post that it isn't the same chirping noise that all of us cummins drivers have come to love!
Old Jan 28, 2007 | 12:34 AM
Got Juice?'s Avatar
Hmmm.. mine is not chirping, just does a couple more revolutions before the truck stops moving... shakes the whole rig.
Old Jan 28, 2007 | 12:48 AM
06dually's Avatar
Mine does the "shake" too.
Old Jan 28, 2007 | 11:59 AM
bigredBCS's Avatar
chirping may not be the right way to decribe it, but every cummins i have ever driven when you shut her down, it shakes the whole truck, and on some the belts make a chirp type sound, maybe a squeak., but i think the guy is saying his actually runs for several seconds before actually shutting down
Old Jan 28, 2007 | 12:11 PM
DynoDynamicsNE's Avatar
My truck does the "wet dog shake" too. The first couple of times I shut it down, I thought there was something wrong, but after a while, I got used to it. I talked to a couple of Cummins owners before I found this site, and they said theirs do it too. Once I found this site, I learned that it's normal due to the high compression these engines have.
You'll get used to it, just give it time.
Old Jan 29, 2007 | 08:53 PM
bigredBCS's Avatar
i still don't think the guy is talking about the "shake"
Old Jan 30, 2007 | 11:03 AM
steelblitzkrieg's Avatar
DTR Detective
Which is it? 2 revolutions or a couple of seconds?
At a 700rpm idle you're getting 11.66 revolutions per second?
With all that compression, it's going to take a second or two to stop.
Old Jan 31, 2007 | 08:25 AM
belgianmagic's Avatar
If you have chipped the motor... some won't shut down till the turbo is cool enough... Edge has that -so you don't cook the turbo...you can shut it off , take the key and walk away and it will run till the turbo is cool enough
