2 fuel system upgrade questions...Air Dog or FASS
Old Mar 2, 2012 | 06:12 PM
beewize's Avatar
This one i dont get. My fuel is pumped from the tank thru a filter that also separates out the water. The filter has a water purge and dash lite if it is required. Then it goes to the high pressure pump for the fuel rail and then to the injectors. Air dog and Fass make a filter to get MORE air and water out of the fuel so as to "extend" injector tips life. There are millions of trucks that have no AD or Fass. Where is the investment return?
Old Mar 2, 2012 | 07:55 PM
hyperrcng's Avatar
Originally Posted by jhenson
I'll have to check the part #....1R-0751...I think....I'll go take a look here in a bit. I had the pump removed from the mounting plate when I put my filter on and there is just enough room to move the bracket and get it away from the filter head. Once you get your clearance just tighten the bracket up and you're good to go.
Thanks for the reply. Used the search and found results for everything but what I wanted. I can get Cat filters easy.
Old Mar 8, 2012 | 01:25 PM
mpracehemi's Avatar
I found Donaldson filters on eBay a couple of yrs ago, bought a case. Should still beable to find 'em on eBay
heavyhighoutput
13
Jan 17, 2013 04:14 PM
IL Ram
24
Feb 18, 2011 10:50 PM
trailinone
16
Jun 19, 2009 04:28 PM
ramsport59
Jun 16, 2009 12:49 AM
jmmcdona
37
Feb 8, 2009 07:20 AM
